Question about Ryobi 18-inch Electric Chainsaw Chain Saws
I need to know how to remove the clutch cover on the 4046c (Ryobi chainsaw)so I can remove the blade and chainge the chain.
  • 3,230 Answers
Check this below link -
http://www.screwfix.com/sfd/i/cat/pdfs/49/p4769649.pdf
Thanks
Posted on Jun 20, 2009
How do I remove the clutch cover from a Ryobi chainsaw?
There are two nuts that hold the clutch cover and chain bar in place. The same nuts you would loosen to adjust the chain tension. Once those are taken off the cover, bar and chain can be removed.
Sep 03, 2016 | Ryobi RCS3535CA 14-inch 35cc Petrol...
My Ryobi 10532 chainsaw chain will not turn. The chain lock is off, it is a new chain. I replaced the old chain as it caught in a stump and stopped turning
pull the chain clutch back towards the handle
it is not a chain lock but a clutch release that stops the chain from turning
pulling it back engages the clutch to drive it
Jul 13, 2016 | Ryobi Garden
Manual ryobi chainsaw
Chain replacement is basically the same on all chainsaws. Loosen the side retaining nuts on the cover over the chain. Now loosen the chain tension screw ( usually a flat headed screw) at least 4 full turns. Put the saw on its side with the blade up. Remove those side cover nuts and the side cover - the blade should sag as you remove the nuts. push the blade towards the engine, paying attention to the direction of the teeth on the chain. remove the chain and clean out the junk from behind the chain around the sprocket and from the inside of the side cover. The emergency brake band is located inside the cover - make sure you clean out the debris from around the band, tensioner screw assembly, and cover. Re-install the new chain, orienting the teeth in the correct direction. Re-install the side cover, making sure the tensioner pin goes into the hole in the bar ( blade). Slightly tighten the side nuts, then re-tension the chain until you can just pull the teeth off the bar. tighten the nuts, being sure you don't over tighten them ( a little past snug is good). Run the saw for a few minutes ( doing 1 cut will speed this step along). Loosen the side cover nuts and re-tension the chain, the re-tighten the nuts.
Hope this helps!!
Nov 26, 2013 | Garden
How to remove clutch from ryobi 20
remove side cover bar and chain clutch may use a special tool to remove
Oct 26, 2012 | Ryobi Chain Saw. 20 in. 46 cc Gas Chain...
We have a ryobi 4046C chainsaw and the oil is not getting onto the chain. Have removed the bar and cleaned the hole where the oil should be coming out from to no avail. This is a chainsaw that hasn't had...
Re problems with oil feed on ryobi 4046C, Oil is fed by worm drive and this becomes worn. Contact Augmented Agents on 0161 477 3388 and they will assist you with necessary parts. if you don't know which part ring 01628894400 they will e-mail you blow up plan and parts list. The drive cog is a left hand thread and can be nocked off with a drift of some description (I used a screw driver held flat) this then exposes screws to access oil pump
Jan 09, 2011 | Ryobi Garden
Need new piston,rings and head for rcs 4046c ryobi chainsaw anyone know were ?
Search for Dixie sales in north carolina,they are the distributer for ryobi parts in the US and Canada, lookint the pricing to determine if its wirth the efforts.check the crankshaft and connecting rod bearings for damage also. Its more then likely that they are damaged from the same problem that caused your piston and cylinder to score
Nov 05, 2009 | Ryobi Garden
My ryobi chainsaw rcs 2040 keeps stopping but motor is still running, chain not moving!
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Sep 21, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Sharpening Ryobi 4046c - what size file ?
Chain Type File File Profile
1/4” Micro 5/32” (4.0 mm) Round
3/8” Picco Mini 5/32” (4.0 mm) Round
3/8” Picco Micro 5/32” (4.0 mm) Round
.325” Micro, Super 3/16” (4.8 mm) Round
3/8” Micro, Super 13/64” (5.2 mm) Round
3/8” Square Grnd Tapered
.404” Micro, Super 7/32” (5.5 mm) Round
.404” Square Grnd Tapered
Depth Gauge File Flat
Jul 11, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I am trying to get the blade off my ryobi 4046c chainsaw so I can replace the chain. I have the two largr bolts off but not sure what else is keeping the clutch cover on.
Shouldn't be anything else. The bar might just be stuck a little through buildup of dust and chips etc. try riggling the back back and forward to see if it will free it. The cover should be removed and the internal areas cleaned after each use for maximum life.
Jun 20, 2009 | Garden
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
61 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
John Wilson
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
