Question about Ryobi 18-inch Electric Chainsaw Chain Saws
How do you change the chain on a ryobi 4046c chainsaw?
  • 297 Answers
You can get the steps to change the chain in this manual. Click here to download the manual
http://www.screwfix.com/sfd/i/cat/pdfs/57/p4750257.pdf
Posted on Jun 20, 2009
What oil does the ryobi use
all oil tanks on chain saws take Bar/chain oil this can be bought same place u buy 2 cycle engine oil most times , this bar chain oil most times is a 30W oil , if you change weights of oil then oil pump is not gonna add proper amount of oil to saw in use ,this will cause u problems !
Jan 18, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
We have a ryobi 4046C chainsaw and the oil is not getting onto the chain. Have removed the bar and cleaned the hole where the oil should be coming out from to no avail. This is a chainsaw that hasn't had...
Re problems with oil feed on ryobi 4046C, Oil is fed by worm drive and this becomes worn. Contact Augmented Agents on 0161 477 3388 and they will assist you with necessary parts. if you don't know which part ring 01628894400 they will e-mail you blow up plan and parts list. The drive cog is a left hand thread and can be nocked off with a drift of some description (I used a screw driver held flat) this then exposes screws to access oil pump
Jan 09, 2011 | Ryobi Garden
Chain not lubricating on Ryobi 4046c chain saw
Have exactly the same problem as you, think the oil pump is the problem but can't find a supplier for the part yet. I blew done the pipe into the oil tank using an air line and it was OK.
May 09, 2010 | Garden
What size file do i use for a Ryobi chainsaw model PCN4545 to sharpen the chain
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Feb 24, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Need new piston,rings and head for rcs 4046c ryobi chainsaw anyone know were ?
Search for Dixie sales in north carolina,they are the distributer for ryobi parts in the US and Canada, lookint the pricing to determine if its wirth the efforts.check the crankshaft and connecting rod bearings for damage also. Its more then likely that they are damaged from the same problem that caused your piston and cylinder to score
Nov 05, 2009 | Ryobi Garden
I bought a new chain to replace the poor one that comes with MY new 18" gas chain saw....but it does not fit into the groove on the bar....the new chain is too wide...the length is perfect though....does...
The difference is the gauge of the chain.The chain comes in .050, .058, and .063 gauge. I am sure that Ryobi does not offer but one gauge bar. This is just one of the many problems of dealing with the box stores rather than a full service qualified dealer. If you can find one in your area, patronize them. Not just when the box store lets you down but for everything. These type dealers are disappearing and are not being replaced and soon they will all be gone. If you can not find one in your area contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Sep 13, 2009 | Ryobi Garden
Engine won't Start on Ryobi RCS 4046C
no spark at plug sends you back to magnita/transformer. ohm it out to see if it has resistance. it should read low resistance. good luck and have a great day please rate bama46, thanks
Aug 16, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Sharpening Ryobi 4046c - what size file ?
Chain Type File File Profile
1/4” Micro 5/32” (4.0 mm) Round
3/8” Picco Mini 5/32” (4.0 mm) Round
3/8” Picco Micro 5/32” (4.0 mm) Round
.325” Micro, Super 3/16” (4.8 mm) Round
3/8” Micro, Super 13/64” (5.2 mm) Round
3/8” Square Grnd Tapered
.404” Micro, Super 7/32” (5.5 mm) Round
.404” Square Grnd Tapered
Depth Gauge File Flat
Jul 11, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I am trying to get the blade off my ryobi 4046c chainsaw so I can replace the chain. I have the two largr bolts off but not sure what else is keeping the clutch cover on.
Shouldn't be anything else. The bar might just be stuck a little through buildup of dust and chips etc. try riggling the back back and forward to see if it will free it. The cover should be removed and the internal areas cleaned after each use for maximum life.
Jun 20, 2009 | Garden
Ryobi battery chainsaw 10" - How do I tighten the chain?
loosen the two nuts that hold the chain cover on. Once they are just loose, then use a flat blade screw driver to turn the slot that you see right next to the base of the chain. Once the chain is tight, retighten the two nuts.
May 23, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi 18-inch Electric Chainsaw Chain Saws Logo
87 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Phil Walker
Phil Walker
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
