Win98 hds in win xp dont show other program says not formatted
I have 2 drives with datafrom a computer that ran win 98. a 40 gig seagate and a 5 gig quantum.form some reason i was having trouble booting to windows. I managed toget it to safe mode and then went to do a normal boot and as it wasbooting to windows i got a black screen saying ''disc protection errorwindows ( or computercant recall ) must restart. After a few times of this i decided that iwould just take the drives out and put them in my other computer sinceall i really wanted was the data from the drives. My new system has 3existing drives. The system disk is 232 gigs and I have two others thatare in raid and show as one drive they are 223 gigs. I have an IDE slotand the power for two more items so i connected the IDE cable and theold drives. I have already done this before with two other drives andmy system saw them and i was able to virus scan and remove viruses andformat my friends drives. This time when i opened my computer icon itonly showed my existing drives and not the two that i had installed. Ithen opened my disk wipe program (Paragon Disk Wiper 8.5 Profesional)that program saw all the drives including the two that i had added. Itshowed the two new ones as unformatted though. I shutdown the comp andchanged the Jumper on the drive to make them both slaves rather thenone master and one slave and rebooted again. with the same result. Iknow the drives are formatted as i had just used them in the oldcomputer. since they wont boot in the old computer and xp doesnt seethem and the other program shows them as unformatted what can i do toget the 45 gigs of data off of the two old drives and on to my currentdrives?
    Sniper:
  • 58 Answers
You will need to revert back to the master/slave setting.  As slave/slave neither disk will be the main controller. Try reverse the master disk to the slave, and the slave to master, as it may be that the controller has a fault which is why you were having the original win98 problem.  Let me know how you get on
Posted on Jun 20, 2009
How to add a new harddisk to a Gateway Peninum 3 550MHz machine and install win98?
Do you want to replaced the main HD or add a new one? If you want to replace the main one, buy a Hard drive under 160 gigs. I cant remember but 98 can not deal with a bigger one, you will have to cut it up or Partition it. Partition it down to 20 gig each. Do you have your Org. win 98 install disk? Get a setup program with the HD you buy. That program should let you Partition it and also format it to use with 98 or fat32. Once installed in the computer set the HD to master with switches located on the drive (small jumpers) As it boots up look for press DEL to enter setup. Get into the BIOS program and ck to see it it will locate your new hard drive you might have to set heads and scetors so make a note of the stamped on the drive. Once the BIOS has found the drive it is a matter of format w/ copy the command comm program from win98 you will have to have a good win 98 set up disk. Once you have formated the drive with fat32 and copied commamd.com you will need to install CD/Rom drivers you might have to find a good old win98 starup disk to boot up the cd. you might find a good old floppy with a cd intall on it at a local computer shop. if using an old win98 startup disk you can then put in the cd and at the Prompt type in cd win98 then type in  setup and that should be a good start.
Oct 23, 2009 | Gateway computers9: Pentium 3 Computer...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Trying 2 trsnfr data off win98 drives to xp drives dont show up
well first of all it would more than likely be a raw data file format for the older 2 drives.
if u are currently running xp with ntfs and know tht the 2 old drives were a fat32 mft then i would recommend using getdataback for fat.
this is the site's info on it
[url]http://www.runtime.org/diskexplorer.htm#DE_FAT[/url]
using this link to d/l the program trial
[url]http://www.runtime.org/gdb.zip[/url]
it will allow you to d/l the program and to also view the contents of the drive. if you know of a way to get the full version of this software then you could take all of the files from the old hd's and paste them to the newer hd just in case you could not recover the files by normal means. i have recovered roughly 10 hd's that could not be seen normally through the disk manager in xp.
also another tips to try is go to the my computer right click and go to manage. try to see if the volume (name) is not mounted. but it the type or format of the hd says raw then your best to use the getdataback program.
easy to follow instructions on how to use the program. is about 4mb in size.
DARK
Jun 20, 2009 | Computers & Internet
How do i format the seagate 5400 160 gig hard drive?
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
There ya go ya tubby *****.Give me a shout this weekend, Mike
Mar 29, 2009 | Seagate Momentus 5400.3 Hard Drive
FORMAT SATA DRIVE 160 GIG
Easiest way is with POWERMAX.EXE from maxtor/seagate website. You can download the bootable ISO from the web and let the software detect the drives and format from powermax.
What I had to do was go into bios and set sata up because the ide channel was primary.But that was just a problem with that board. I was at my church camp and didn't have internet or my software so I set up sata, boot from cd, put in win98 cd, boot with cd support,
at the prompt, typed fdisk, to detect HD, after setting up the harddrive closed out fdisk and at prompt typed cd d:\win98 to change directory to cd win98 dir. then typed format c:\
Mar 01, 2008 | Maxtor Hard Drive
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Restoring Partition
If you did the install by formatting C drive, it was a clean install and all other data from Win 98 will be gone. Also XP uses NTFS rather than only FAT. It becomes a real mess when you try to install XP over 98 without starting on a clean slate.
Nov 05, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r windows........win-xp-sp2
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
