Question about Konica Minolta Office Equipment & Supplies
TECH SUPPORT ENTER FACTORY SETTING
  • Konica Minolta Master
  • 6,696 Answers
Stop00 stop01
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
Reset factory setting
Dear
Go to tech mode -menu + # + 1934. in sequence within 4 sec.
press menu go to TECH MODE press enter. scroll for display DATA SETUP-enter- scroll for mem.clear.
Thanks.
Aug 21, 2014 | Samsung CLX 3160fn All-In-One Printer
Need to factory reset Knonica Minolta C350
You have must be entered in Tech.rep mode.
Press Utility key - Meter count - Check details - Stop -00-Stop -01 and select machine settings or system 1 or system2.
If you need to enter in Administrator mode the Minolta password is 12345678 or 00000000 and press Enter.For more details please contact me.
Apr 19, 2013 | Konica Minolta bizhub Office Equipment &...
How do i remove the word factory on the screen
I have the link to the service manual but first I want you to try something, with set off and using the Sony remote:
Display, 5, vol up, power.
when set comes on it will or should be in tech menu----Depress only the number 8, followed by enter.
On pressing the 8 the word reset should appear in red, and when enter is pressed it should change to green.
DO NOT PRESS ANY OTHER BUTTONS WHILE IN THE MENU.
TURN POWER OFF with the button on the set. Wait for the fans to stop (5 min) and remove power from set. A few minutes later plug power back and turn on set to see if you are now out of the factory mode.
Let me know and if you want the link for the full manual I will get it for you.
Dec 18, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i restore factory settings to Sony Bravia KDL 32w5500?
The old standby for almost all Sony sets is with the set off:
(remote control-Sony)
Display, 5, Volume up, power
With set then on the display should show the tech menu
Press 8 and (set will display or should RESET in red, then press enter and it should (reset) turn green---this has been the standard reset on their set for several decades.
Nov 06, 2012 | Sony BRAVIA KDL32V5500 32 in. TV
How to restore my factory setting of nokia 7210c
To restore Go to Menu>Settings>Restore Factory Settings>Enter security cod(Default will be 12345)
Thank You
Don't Forget To Rate
Jan 25, 2011 | Nokia 7210
Just purchased a 2003 mountaineer from a used car dealer and they don't have the manual and the alarm doesn't work. How do I get the factory entry code?
the keyless entry code is on the module and in the module memory. A dealer can extract the code ( about $50). You can access the owner manual on line at motorcraft.com, pro center, tech info, owner manual. I have one for $7 plus postage. let me know. Also, look for a plastic credit card in teh glove box with the code on it. The module should be under the dash, driver side I think.
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it overwrites the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system now responds only to the factory set code.
Anti-Scan Feature
To provide added security, the keyless entry pad is disabled for one minute after 35 button presses without a valid entry code being entered. The keypad flashes during this one-minute mode with all functionality disabled except for 7/8 and 9/0 still being allowed to lock the vehicle.
Anti-Scan will be turned off after one minute of keypad inactivity.
Unlocking the Doors and Liftgate with the Keyless Entry Keypad System
To unlock the driver door, enter either the factory set code or the personal code (each digit must be pressed within five seconds of the prior digit). The interior lamps will illuminate.
To unlock all doors, enter either the factory set code or the personal code (driver door unlocks) and press the 3/4 control within five seconds.
To open the liftgate window glass, enter the factory set code or the personal code (driver door unlocks) and press the 5/6 control within five seconds.
Locking the Doors with the Keyless Entry Keypad System
It is not necessary to enter the factory set or personal code prior to locking all doors. To lock all doors, press the 7/8 and 9/0 controls at the same time
Dec 21, 2010 | 2003 Mercury Mountaineer
Locked up factory settings on My Olevia
On the remote, hit the "Menu" button and then press the down arrow until you see "Picture," then hit enter, now hit the down arrow until you see "mode" and hit enter again. You should then see "power up" displayed. Hit enter again to get to the setting choices where you can change the mode back to "home" (hitting enter one more time) then exit the set-up menu.
Jun 07, 2008 | Olevia LT32HVM 32 in. LCD Television
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Jan 22, 2008 | Philips 50PFP5332D 50 in. Plasma...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
