Question about Cell Phones
WOULD LIKE TO KNOW ON STEREO SYSTEM SG-2100 WHICH TYPE OF MICROPHONES ARE USED FOR PUBLIC ADDRESS SERVICE (DYNAMIC ? PIEZOELECTRIC ? MODERNST PRE- AMPLIFIED IN A VERY SMALL CONTAINER ? AND WHICH SOURCE IMPEDANCE ? HIGH , LOW ? HOW MANY K-OHMS OR SIMPLY OHMS ?) THANKYOU VERY VERY VERY MUCH ! Radio-Ham i2DKK Gianfranco PARINETTO Sabòtino , 11 ( I-20030 ) PALAZZOLO MILANESE - Italy Phone xxxx 02 9182267 In INTERNET : parinettog @ libero.it
  • parinettog Jun 21, 2009
    It's NO (repeat NO ) Cellular Phone ! ! ! ! IT IS AN OLD PANASONIC SG-2100 STEREO SYSTEM
    WITH TURNTABLE 78-45-33 L.P. SPEED. ITS INTERNAL AMPLIFIER COULD BE USED WITH
    MICROPHONES TO ADVISE PEOPLE ( PUBLIC ADDRESS COMMUNICATION ). WHAT I NEED
    TO KNOW IS THE TYPE OF MICROPHONES TO MATCH WITH IT ! ! ! !
    THANKS
  • 3,230 Answers
Hi therer,
You can use a pre-amplified microphone with this unit.
This question is little confusing... Can you please explain some more about what you want to know?
Thanks
Posted on Jun 20, 2009
  • Mukesh Kumar Jun 21, 2009
    ok... u use a pre-amplified microphone.
192.168.0.13
77.248.24.119 is the dns from the internet service provider
192.168.0.13 is the router address
Jul 07, 2015 | Computers & Internet
I need to know how to complete my setup I got as far as the setting screen where they ask u your IP address etc. Now I can't get in to complete the set up. What do put in those blanks that ask for you
If you are in the Router setup, (and not a PC setup,) then that would only apply if you had a "Static" Public IP address, (this is an address that never changes, vs. 'Dynamic' ones that do change.) Usually only a business would have 'static' Public IP addresses, and the Internet Service Providers (ISPs) charge extra for them.
Without knowing more about the make/model Router you have, it would be difficult to give you further instructions, but look for settings that would assign the IP address 'automtically'
Oct 12, 2014 | Computers & Internet
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
Sep 15, 2014 | Computers & Internet
WHAT IS ICP
An integrated circuit piezoelectric sensor or ICP sensor is a device used to measure dynamic pressure, force, strain, or acceleration. It contains a sensing element made of a piezoelectric material, which converts mechanical strain into an electrical signal, and anelectronic circuit to amplify this signal and transmit it to an external device.
ICP is an abbreviation of "integrated circuit piezoelectric", and is a registered trademark (no. 1,603,466 in the USA) of PCB Group, Inc., parent company of PCB Piezotronics.[1] There is a similar non-proprietary standard called IEPE, which stands for "integrated electronics piezoelectric."[2]
In an ICP sensor, the built-in electronics convert the high-impedance charge signal that is generated by the piezoelectric sensing element into a usable low-impedance voltage signal that can be readily transmitted, over ordinary two-wire or coaxial cables, to any voltage readout or recording device. The low-impedance signal can be transmitted through long cables and used in dirty field or factory environments with little degradation. In addition to providing crucial impedance conversion, ICP sensor circuitry can also include other signal conditioning features, such as gain, filtering, and self-test features.
The electronics within ICP accelerometers require excitation power from a constant-current regulated, DC voltage source. This power source is sometimes built into vibration meters, FFT analyzers, and vibration data collectors. A separate signal conditioner is required when none is built into the readout. In addition to providing the required excitation, power supplies may also incorporate additional signal conditioning, such as gain, filtering, buffering, and overload indication
Aug 14, 2014 | Cars & Trucks
Change ip address
Type cmd in Start menu-Run. A little black window will open. Type: ipconfig/all and Enter. It'll list your IP among other info.
If you want to change it: Start menu->Control Panel
Type "adapter" int the search box. You'll have "Network and sharing Center". Click "View network connections". Select "Internet Protocol version 4 (TCP/IPv4)" and click Properties. There you can change your IP settings.
Jan 17, 2014 | Lenovo IdeaPad Computers & Internet
How much price value
The Escort's integrated design allows for ease of transportation, while its user-friendly controls offer ease of operation, making it the perfect choice for schools, churches, civic organizations and small musical groups. The Escort features dual two-way speakers driven by a five-channel, 300 Watt stereo powered mixer, making it ideal for both vocal and musical applications. The system also includes a PV®i unidirectional (cardioid pattern) dynamic microphone, two folding speaker stands and all necessary connecting cables. Among many professional features, the mixer includes 60mm faders, a five-band graphic equalizer with FLS® (Feedback Locating System) and digital reverb. The carrying case provides storage for all the system componets with ample room for additional mics and cables. This clever design incorporates the speakers into the package, allowing the unit to be easily carried or pulled along on its luggage-style wheels.
Specification
  • Convenient package with luggage-style wheels
  • Two-way speaker system with 10" woofer and piezoelectric horn
  • Five-channel powered mixer
  • Four XLR mic inputs with 15 V phantom power
  • Two stereo line inputs
  • 60 mm faders
  • High quality digital reverb
  • 300 Watts output power (150 Watts per channel) with DDT™
  • Five-band graphic equalizer with FLS
  • Two folding speaker stands
  • One PV®i cardioid dynamic microphone with cable
  • Two 25' speaker cables
  • Storage compartments for microphones, cables and accessories
  • Weight Packed: 64.00 lb(29.029 kg)
  • Width Packed: 16.62 x Depth Packed: 39.75 x Height Packed: 17.62
£499.00.
$649.99
$649.99
May 05, 2011 | Peavey Escort 2000 Microphone
Will not connect to internet completed all connection but cannot connect to internet
Router's have their usual way for them to work with your preferred Cable / DSL Internet Service Provider.
Cable Internet usually requires a MAC clone and power cycle to work properly while DSL Internet often required a username and password that came with your DSL povider.
If you want to configure your D-Link router then try accessing it Web Interface;
This instruction is for Cable modem installation however if you're using DSL modem then just change the WAN connection type to PPPoE and type your user name and password.
Step 1 Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. The username is admin (all lowercase) and the password is blank (nothing).
Step 2 Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
Step 3 Power cycle the cable modem and router:
  • Turn the cable modem off (first)
  • Turn the router off
  • Leave them off for 2 minutes**
  • Turn the cable modem on (first)
  • Wait until you get a solid cable light on the cable modem
  • Turn the router on
  • Wait 30 seconds
Step 4 Follow step 1 and log back into the web configuration. Click the Status tab and click the Device Info button. If you do not have a public IP address under the WAN heading, click on DHCP Renew and then click Continue. It may take a few minutes to obtain an IP address.
Hope this helps!
Oct 15, 2009 | D-Link Computers & Internet
IP Address
To check your IP you need to Go To Start Rum and type cmd and enter
You will find a DOS screen poped up . you need to type Ipconfig . It list you your IP. You need to have a local admin to change your IP
Dec 20, 2008 | Computers & Internet
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
