Trying 2 trsnfr data off win98 drives to xp drives dont show up
I have 2 drives with data from a computer that ran win 98. a 40 gig seagate and a 5 gig quantum. form some reason i was having trouble booting to windows. I managed to get it to safe mode and then went to do a normal boot and as it was booting to windows i got a black screen saying ''disc protection error windows ( or computer cant recall ) must restart. After a few times of this i decided that i would just take the drives out and put them in my other computer since all i really wanted was the data from the drives. My new system has 3 existing drives. The system disk is 232 gigs and I have two others that are in raid and show as one drive they are 223 gigs. I have an IDE slot and the power for two more items so i connected the IDE cable and the old drives. I have already done this before with two other drives and my system saw them and i was able to virus scan and remove viruses and format my friends drives. This time when i opened my computer icon it only showed my existing drives and not the two that i had installed. I then opened my disk wipe program (Paragon Disk Wiper 8.5 Profesional) that program saw all the drives including the two that i had added. It showed the two new ones as unformatted though. I shutdown the comp and changed the Jumper on the drive to make them both slaves rather then one master and one slave and rebooted again. with the same result. I know the drives are formatted as i had just used them in the old computer. since they wont boot in the old computer and xp doesnt see them and the other program shows them as unformatted what can i do to get the 45 gigs of data off of the two old drives and on to my current drives?
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
Well first of all it would more than likely be a raw data file format for the older 2 drives.
if u are currently running xp with ntfs and know tht the 2 old drives were a fat32 mft then i would recommend using getdataback for fat.
this is the site's info on it
[url]http://www.runtime.org/diskexplorer.htm#DE_FAT[/url]
using this link to d/l the program trial
[url]http://www.runtime.org/gdb.zip[/url]
it will allow you to d/l the program and to also view the contents of the drive. if you know of a way to get the full version of this software then you could take all of the files from the old hd's and paste them to the newer hd just in case you could not recover the files by normal means. i have recovered roughly 10 hd's that could not be seen normally through the disk manager in xp.
also another tips to try is go to the my computer right click and go to manage. try to see if the volume (name) is not mounted. but it the type or format of the hd says raw then your best to use the getdataback program.
easy to follow instructions on how to use the program. is about 4mb in size.
DARK
Posted on Jun 20, 2009
Seagate freeagent goflex 3tb goes to sleep
It is probably not a problem with the Seagate. It is more likely the computer has turned off the USB port to save energy. This article is from HP but it should apply to your situation, follow the instructions. HP and Compaq PCs USB Devices Quit Working Unexpectedly Windows XP HP...
May 13, 2017 | Seagate Freeagent Goflex Desk 3 TB Desktop...
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Win98 hds in win xp dont show other program says not formatted
you will need to revert back to the master/slave setting.  As slave/slave neither disk will be the main controller. Try reverse the master disk to the slave, and the slave to master, as it may be that the controller has a fault which is why you were having the original win98 problem.  Let me know how you get on
Jun 20, 2009 | Computers & Internet
Seagate STT63200P Win XP Driver
I would suggest you have to put it on a Windows 95 computer as I have a unit and the Driver should go with a windows 95 just to get your data.
Cheers
Mar 04, 2009 | Computers & Internet
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Not able to back up my collection of mp3 second time around
My friend 1st win98 do not have abilities to respond more then 80bg if you lucky. Try someone else computer like your best friend who has Win 2000, XP, Vista,.
May 31, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Restoring Partition
If you did the install by formatting C drive, it was a clean install and all other data from Win 98 will be gone. Also XP uses NTFS rather than only FAT. It becomes a real mess when you try to install XP over 98 without starting on a clean slate.
Nov 05, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 80 GB laptop hard drive not appearing in My Computer
i suggest u to re instal u r windows........win-xp-sp2
remember- dont keep 2 operating system on u r hardisk man
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 26, 2007 | Seagate Momentus 5400.3 Hard Drive
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
