SOURCE: INOVIX IMP-1112 MP3 crashing my computer.
sounds like bad news - if the flash (update to firmware) failed during update, the item is more than likely dead. Warranty return possible? Can you try another usb device on that same pc? just to verify the usb ports are working properly and supplying proper power to the devices.
SOURCE: down laoding music
iTune format will not play in a MP3 Player, you must first convert them to MP3 format.
SOURCE: inovix imp-1112 mp3 player problems
Hi. I've had similar problems with the same model.
Have you tried a Firmware re-install yet? If not, do that first using the CD supplied with it.
Whilst it's plugged into your USB port, it'll hopefully also get a bit of a charge. I notice on mine that the player will only charge from the USB port when the side on/off switch is in the 'on' (up) position, although there are times when the computer will 'reject' the player with the switch in this position - a series of 'ding-dongs' as it connects and disconnects from the USB port!
If this happens to you, just keep trying! Come back to it each day, and try another Firmware re-load!
Mine took a few days, but then decided to come to life - weird machine!
SOURCE: INOVIX IMP-1112 POTABLE MP3 PLAYER -driver is gone
My Mp3 Player Starting Problum Plaz Help Me
