Question about Toshiba Satellite P105-S6104 Notebook
My toshiba satellite m30 display is not coming up in eiher inbuilt or external monitor, keys r working hdd led not litting up, cd rom working. front panel leds r all gud, vertical lines come up when pressing button on side panel
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 29 Answers
One of 2 things you can do.
first try to see if you can press down and hold the fn or function key and then press one of the F1 or F2 buttons at the top that shows a monitor picture and press that button and let both go.
see it will the screen to switch form internal to external and back again by repeating.
second you will have to go to safe mode when the computer is restarting and tapping the F8 key while it is loading from first stating it. make sure to tap the F8 only 1 or 2 a second otherwise keyboard will occur.
once you get into the safe mode you need to login through your login that has the problem and once in there you need to go to the display properties page and click settings and adjust your resolution down to the lowest setting there is and then reboot.
see if that corrects the issue with 1 of the 2 solutions.
DARK
Posted on Jun 20, 2009
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Check your settings,both bios and display,for the display priority.Either the settings has been set to inbuilt display and thus cant display on external monitors or the external monitors have been disconnected in bios settings
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
Hdd light does not come on during power up on toshiba l555d-s7005
If the screen stays black it means there is an issue with BIOS. It should load before the HDD ever does. Mother board issue or monitor issue.
Dec 29, 2017 | Toshiba Satellite L555D-S7005 Notebook
Laptop wont turn on, got green pwr and amb bat but will not fire up
Systems covered: All failing to boot without lighting up display.
Goal of this Solution: Try to determine whether system is (a) booting successfully while failing to light its display (indicating hardware failure in the display), or (b) failing to light the display due to failure to successfully transfer control to ROM BIOS (indicating a motherboard failure).
The fact that the Green power LED, and Amber Battery LED are lit seems to exonerate the laptop power supply (brick) circuitry. Even with a nearly dead battery, a Toshiba Satellite 1135-s1552 should work while plugged into a properly functioning brick.
Here's Toshiba support's (244 page) online PDF version of your laptop manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=434997&rpn=PS113U&modelFilter=1135-S1552&selCategory=2756709&selFamily=1073768663
If the HDD (hard disk) activity indicator LED is active after power-on, then your system has actually got past BIOS and is booting - your LCD monitor inverter circuit or Backlight may have burned out - and to use the system, you'll need to connect an external monitor to the RGB monitor port on the back of the system (see illustration on page 32 of User's Guide) to view system activity.
Alternatively, one may attach an analog TV, using the S-Video port on the back of the laptop (see illustration on page 32 of User's Guide).
Once an external monitor is working to display the ROM BIOS part of the boot sequence, you may find that the ROM BIOS is good enough to run a few BIOS-based diagnostics. Run them all - something may indicate the source of the boot failure. Ofttimes, enough of the motherboard remains good to provide interaction with the ROM BIOS, but some motherboard failure will subvert a full boot to Windows/Linux. An example of this type of failure would be a failure of the PCMCIA bus controller, which is vital for booting a disk-resident OS, but unaccessed (except by BIOS diags) when the user interacts with BIOS. Another common failure of this type is main memory (RAM) failure.
A working external monitor/TV also provides a chance to backup important laptop data to a flash drive, sky drive, or CD-RW discs.
If no HDD activity is seen after power-up, then either your BIOS is hosed (in which case you'll need a new motherboard), or another motherboard component is hosed (in which case you'll need a new motherboard).
You may want to transplant the HDD into a working PCMCIA-bus system (any laptop) to recover/backup your important data.
If someone recently attempted and failed to update the motherboard's ROM BIOS, then you know why the system is failing to boot and also failing to light the display.
Here's a link to a site with disassembly instructions for Toshiba laptops:
http://www.irisvista.com/
Most dead laptops (even those whose power supplies have been burned out by a nearby lightning strike with the system on 120 VAC power) will still have perfectly usable HDD module(s), and RAM memory cards, so that at the very least, these removable components may be recycled into memory reserves for your next laptop or sold (Ebay.com) to help defray the cost of a new system.
Dec 14, 2011 | Toshiba Satellite Computers & Internet
Toshiba satellite m30 screen is blank after starting!
I had the very same problem with my Toshiba LP, ended up replacing the screen, it broke. And there is nothing that you can do to fix it by yourself, unless you are a tech
Apr 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
Toshiba satellite pro a40 power problem
There is no power on the cable that comes from the mains to the power block. Check the cable for continuity.
Mar 03, 2017 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Hi I only see blinkingorange LED light when power
Its seems to be very low Battery. You can remove Battery and re plug it again and check.
Also you can check it by starting your notebook with ac power on.
It problems is still there then you notebook needs to get serviced on autorized service center.
Mar 22, 2010 | Toshiba Satellite M30 Notebook
Toshiba Satellite P105-S6104 Notebook Logo
259 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
