Hi, ive got a simpson delta 10 and it wont agitate. the knobs clicking like its going to start. it fills up with water and the pump and belts are o.k. thank you
The motor could be blown. I had one of these washers and the clicking of the controller means that power is getting to the washer control unit on the front panel but not to the motor. The water level switch should stop the filling and go to the next part of the cycle.
Posted on Jan 24, 2010
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Washer filled and will not drain if I reset the fill capacity knob it will fill but not drain.
This washer has a belt. The belt drives the pump on this washer. The motor turns in both directions. iIn one direction the washer tub is locked and the tranny agitates. The water pumps out and the tub spins in the other direction. If that pump is locked up or the hose from tub to pump is blocked then it wont pump the water out. Lay the drain hose down towards a bucket and see if any water comes out. If not you got blockage. Once you drain it out tip is back and remove the belt (no tools needed) turn the pump both directions and look for signs of a failed pump. Manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 30, 2011 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Hi, when pulling the select knob, no water, just the agitator.
Bad timer, the timer is not telling your system the correct setting and just jumping to a setting of its choice. Once the timer is replaced everything will work just fine.
Jun 01, 2010 | Washing Machines
Simpson delta 422 fills but agitator doesnt start . i
the timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Washing Machines
Washer fills but wont agitate
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion......
Jun 25, 2009 | Kenmore Washing Machines
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Wont agitate
Hi, Try these:
  5. Test the motor
please rate my suggestion....
May 22, 2009 | GE Washing Machines
Washing Machines Logo
360 people viewed this question
Top Washing Machines Experts
