Question about LG Studioworks 560N 15" CRT Monitor
Tda9309 replacment what is replacemet for tda9309 vertical for my philips monitor? help plzzz. bec. no stock in my area...
Vertical line in monitor
theres no way to fix vertical line on lcd the only way is to replaced lcd panel with same panel type
Feb 28, 2014 | Philips 17" LCD Monitor
Smart image on philips lcd on screen
Dont Buy Philips monitor. I have 20 pcs monitor and after one year half of them had malfunction. smartimage with vertical lines back and forth and that all controls are locked that cant be unlock by holding any button. Some had white screen when Resolution exceed 1024X768 (when 1280X768) after a year.
Maybe they program it to malfunction after a year. My CDR king and AOC monitor had no problem 2yrs to present date.
Philips monitor are garbage
Sorry for bad english.
Sep 22, 2011 | Philips 220CW8FB 22" LCD Monitor
Ls developed vertical coloured lines which cover half the screen, I have attached an external monitor which works perfectly any ideas how the laptop screen can be repaired
I would checkout ebay for a replacemet screen and just change it. If you get a screen and then get lost, post another question and we can help you take the laptop apart and put it back together.
See www.insidemylaptop.com there may even be your model laptop having a screen replaced. They are all fairly similar to work on.
Hope that helps.
Mar 06, 2011 | HP Pavilion dv9000z Notebook
Osd lock popup and maina menu popup is continously blinking on my monitor screen plzzz help me how can i remove it? i have view sonic monitor E70FSB...plzzz help me out
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..
in case case of 45Bn & 55V..look for Controller Reset IC201/IC202 (KA7045/KA7045AP) [it is a small alike transistor 3 pin IC !!] along with the afore said..
and in case of 56V..look for +14V SW. Transistor A1281 & C945 (therein) along with the afore said..
..beware u must b a professional..
contact ur system admin/vendor....
Nov 02, 2009 | Computers & Internet
VGA PIN
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Jul 17, 2009 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 560N 15" CRT Monitor Logo
50 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
