Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
I have HP Scanjet 5300c working with WinXp but Mac Leo -no way
I run it under Virtual Machine without any driver installations
  • nightsnipers Jun 24, 2009
    thanks but I 've already bought VueScan and it communicat well with my old good scanner :)
    Scholar:
  • 119 Answers
Try downloading the Mac drivers at address http://www.cnet.com.au/downloads/soa/HP-ScanJet-5300c/0,239030384,2113661s,00.htm
If that doesnt solve your problem, you might to make sure your virtual machine is actually able to communicate with the physical computer and is able to access its resources
Posted on Jun 20, 2009
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
Mar 24, 2012 | MGI Software PhotoSuite SE V4.0
Drivers HP scanjet 4400c for windows 7
This worked for me:
Do NOT connect scanner before these first few steps
1. Download & save win xp drivers from HP website: http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=28447&prodTypeId=15179&prodSeriesId=28441&swLang=8&taskId=135&swEnvOID=228
The 63.4mb file is the only one you'll need
2. Right-click on the saved file and go to its properties. Under the compatibility tab, set the file to run with win xp service pack 3. Apply changes and close properties dialogue.
3. Right click on the same file and choose 'run as administrator'. Accept any windows prompts that may appear and let the program & drivers install.
4. Once the software has finished installing, connect the scanner to your computer (via USB) and turn the scanner on.
5. Restart the computer without unplugging or turning the scanner off.
6. Your scanner should now work fine with the HP Precisionscan Pro utility.
Oct 31, 2011 | HP Scanjet 4400c Flatbed Scanner
PREVIOUSLY USED WINDOWS XP -NEW MOTHERBOARD IN MY COMPUTER- have INSTALLED WINDOWS 7- MY GENIUS COLORPAGE HR 3200 SCANNER NEEDS A COMPATIBLE DRIVER. CANNOT FIND FOR WIN 7
This is unfortunately a common issue with "older" devices with Windows 7 not supporting a compatible device driver:. Your best chance is to install Windows XP in a Virtual Machine under windows 7: the free ''VirtualBox'' virtual machine is what I personnaly use for my incompatible devices.
Hope it helps.
May 15, 2011 | Office Equipment & Supplies
Hi, I need driver for windows 7 I try install for xp and run like in xp but it is not working if you have any tip I will be thankfull
Hi marec2009
Unfortunately , you don't tell us what device is concerned with this compatibility problem .
If nothing works , uncluding troubleshooting in compatibility XP , the only way to get out of the issue is a workaround : installing a virtual version of XP on your machine but you can do it only under restricted conditions :
You are running Windows 7 Ultimate , or Professional or Entreprise :
you can download and install a free virtual version of Win XP from : http://www.microsoft.com/windows/virtual-pc/download.aspx
Other versions :
.If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Best regards .
fanaudi
Apr 28, 2011 | Computers & Internet
I have a new windows 7 computer and want to use my white 4400 embroidery machine on it. How do I load a new driver for my machine?
Unfortunately, it seems that the company that bought the White brand (SVP) has no interest in creating new drivers for the machine. Is your computer running the 32-bit or the 64-bit version of Windows 7? (Start > Control Panel > System and Security > System. If you see x64, you have the 64-bit version.)
If you have the 32-bit version, you can try the compatibility mode. With the White USB drive connected to the computer, right click on the installer instead of normally running the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software that came with the sewing machine in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
Apr 17, 2011 | White Sewing White 4400 Computerized...
I need a driver in order to be able to use my Sony voice recorder ICD-P520 on Windows 7 64 bit
Unfortunately, Sony does not support this recorder under Win7 64-bit. See http://esupport.sony.com/US/perl/swu-list.pl?mdl=ICDP520&SelectOS=27 for the available drivers. You can try the Vista or WinXP driver with the compatibility mode. (This may involve allowing unsigned drivers since there is no information on 64-bit compatibility on either the Sony or Microsoft Vista Compatibility site.)
To try this, download the driver and right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Mar 14, 2011 | Sony ICD-P320 Digital Voice Recorder
I can't find drivers and the software for my scaner SCANJET 5400c I have win7 64bit
Unfortunately HP has not made a vista or windows 7 driver for this model older drivers will work under these newer operating systems but will not install under 64Bit systems.
you have to option run windows in a virtual machine with 32 bit to use this hardware or downgrade and install windows 78 32 bit on your pc to allow drivers to install for this hardware
32Bit Driver Link
Feb 25, 2011 | Computers & Internet
Need printer driver for windows 7
Hi, David. I had the same problem, and there is a solution. There isn't a driver for Windows 7, but under Windows 7 you can install a virtual machine, that runs a fully licensed copy of XP on your machine. You can download this from Microsoft. Once you have installed a virtual XP machine (and it's not hard at all to do - maybe 10 minutes), you can load the DYMO software and drivers for XP, and your LabelWriter EL60 will work just fine.
Regards,
- Jim
Dec 16, 2009 | Dymo LabelWriter EL60 Thermal Printer
I absolutely hate vista....i wasn't able to transfer my microsoft money so had to download quicken and transfer info...then twice now i have had to reinstall quicken because it won't open up...i guess it...
There is a work around to getting Windows XP programs to work under Windows Vista - Virtual PC 2007.
Virtual PC 2007 is a free download from Microsoft and it allows you to install any operating system and run it in a "window" on your Vista desktop.
Download Virtual PC 2007, create a Windows XP virtual machine, install Microsoft Money and transfer in your data. You can install Quicken as well.
The virtual machine will use your PC's actual connections (network, serial and printer but not USB) to connect to devices and the Internet.
Again - this is a work around that is proven to work. One side benefit - you can copy the virtual machine to an external hard drive / USB memory stick and run it on any comptuer that has Virtual PC 2007 installed on it.
Hope this helps
Nov 18, 2009 | Microsoft Windows Vista Ultimate Edition
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
292 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
