Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Its take a long time to start the tv.no display in the lcd.what is the problem in this tv?
  • 79 Answers
Probably short on power or there is a damaged cord in the plug. Do you hear any sound? If so, the LCD of the TV is the problem. Have it fixed if the warranty is still available and not expired.
Posted on Jun 20, 2009
Samsung lcd tv la22a450c1 in standby mode all the time, no display.
Faulty capacitors in the power supply is most likely but it may have damaged the other boards whilst it was failing.
Jan 06, 2018 | Samsung Dishwashers
Sony LCD KLV32BX35A 5x Blinking Problem.
When an LCD TV turns on for a little while, and then dies, problem usually capacitors or IC's in Power Supply section, specifically diode bridge in Inverter board, or T-Con timing board.
Jul 17, 2014 | Sony KLV-32BX300 32 inch Multi-System LCD...
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 16, 2014 | Acer AL Computers & Internet
Replace power supply board on nexus 50" plasma hdtv
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | CTL Nexus NX2403 24 LCD TV
My TV are blisting of left half display or black out of that. Hit or pressure on the back make sometimes full display well.
Hello
It is due to some loose fixation with its flat cables that connected to lcd disply screen to its T'con board. T'con [Timing Control] board is the driving board to LCD display. If there is some loose contact, the fault you describes here can occur. Just open the TV, and detach and reattach each flat cables that connects with T'Con board ot LCD screen. This must solve the probel of your TV. OK.
Nov 23, 2011 | Dynex DX-L42-10A 42 in. LCD TV
My Sharp LC-60C46U LCD TV will not display any Menu or Volume items on the screen, it also started to display horizontal lines in several areas on the screen at the same time as the other problem. Any...
Dear guestcomp,
This problem is due to faulty display panel.So replace it with new one.It will solve your problem.I think it helps.Let me know.
Jan 04, 2011 | Sharp LC-60C46U LCD TV
When the first time my computer connect to the lcd tv is working but when I do again it show no signal on the tv.. what is the problem
Press start then choose control panel. On "Mobile PC" choose "adjust commonly used mobilty setting". Then choose connect display. Then choose how you want it to display on the lcd TV.
Jul 03, 2010 | Insignia LCDTV26 26 in. Television
W2606c lcd tv
Nothing appears on my LCD TV display
1 Ensure the LCD TV display is turned on.
2 Verify that all the cables are properly connected to the LCD TV
display, including the power cable.
3 Check to see if there is a blue or amber light on the lower,
right-hand corner of the LCD TV display. A blue light indicates
the LCD TV display is on. An amber light means the LCD TV
display is in power save mode.
4 Ensure the proper source is selected in the Input Select menu.
See "Input Select Menu" on page 24 for more information.
5 Reconnect any devices that are currently connected to the LCD
TV display. If you are using multiple devices, connect and test
one device at a time.
6 Connect another device that you know is working properly.
7 Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset.
Problem Possible Solution No sound
1 Ensure mute is not turned on. Pressing the Mute button on
the remote control turns the mute function on and off.
2 If only certain LCD TV channels do not have sound, then you
need to correct the Input Select menu in the TV Menu (see
"Input Select Menu" on page 24).
3 Verify that the audio cables are firmly connected to both the
audio input connectors on your LCD TV display and audio
output connectors on your devices. Ensure that the cable colors
match the connectors colors.
4 Also, ensure that the audio cables are connected to the same
row as the video cables. See "About Your LCD TV Display" on
page 5 for the location of the connectors.
5 Reconnect the device using the same type of connector. For
example, if you are using the composite connector on the
bottom, try connecting the device to the composite connector
on the side of the LCD TV display. See "About Your LCD TV
Display" on page 5 for the location of the connectors.
After you connect the device, change the input source in the TV
Menu. See "Input Select Menu" on page 24 for more
information.
6 Connect the device using a different connector. For example,
if you are experiencing the problem using a composite
connector, try using the component connector.
NOTE: To connect to a different connector, you need the
appropriate cables for that connector. See your device
documentation for a list of supported connections.
information.
7 Test the device on a different TV.
Jan 05, 2009 | Dell Televison & Video
Sharp Aquos LCD intermittent display
Hi there.
The backlight inverter board is defective.
Replace it and your problem will be solved.
Oct 15, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Display screen problems.
Either the LCD or the connector/connections are at fault.Check them physically for a loose connection due to humidity or dust. Replace LCD and we can help for original LCD and instructions. mail us further. Siva
Jul 27, 2007 | Sony Cyber-Shot DSC-P41 Digital Camera
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
