Question about Panasonic Lands Phones
KX-TGA110FX I've canceled base on registration and how can i back the base
I have the same problem...please help.....dejansredic@gmail.com
Posted on Feb 09, 2010
How to register Panasonic KX-TGA-405 Range Extender with existing Panasonic Base Model KX-TGF570
According to the manual for the KX-TGA405, you need to do the following steps to register the range extender to any compatible base (including the KX-TGF570). First, unplug the range extender's AC adapter. Press and hold the Locator button on the base (KX-TGF570) for 5 seconds or until the registration tone sounds. Within 90 seconds, plug in the KX-TGA405 AC adapter. After the status indicator light on the range extender becomes green, press the Locator button on the base to stop the registration tone. Depending on where you place your range extender, you may need two people with two-way radios to complete these steps in the 90 second time limit.
See page 4 of the KX-TGA405 manual for the Deregistration/Registration steps. Panasonic has the manual here: ftp://ftp.panasonic.com/accessory/phone_fax/om/kx-tga405_en_om.pdf .
I hope this helps.
Aug 22, 2017 | Panasonic Lands Phones
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
Kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Nov 04, 2008 | Panasonic KX-TG1100 Cordless Phone
KX-TGA110FX
1.Press (ok)
2.Arrow down(twice) to "setting BS" then right
3. Input PIN code.Usualy 0000
4.Press "1"if you want TONE dialing or "2" for PULS
5.Press right arrow,then on/off button
Oct 30, 2008 | Lands Phones
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
You are now done!!!
Good luck
Simos
Feb 28, 2008 | Panasonic KX-TG1100 Cordless Phone
How to disable dial lock without password
I am using panasonic PANASONIC KX-TG2620BX and was locked by my daughter. We had it unlocked by:
press MENU
select Dial lock
Enter password 1234
Press save
Turn off Dial lock? press yes
Jan 08, 2008 | Panasonic 5.8GHz Cordless Telephone
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Lands Phones Logo
858 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
