Question about Thermaltake Toughpower 750-Watt Power Supply
Not Sure What Power Supply to use in my computer
Hi Hows it going?
I just bought parts to build a computer my problem is I have a 750W Power Supply And I'm just wondering if thats sufficient for my system. The Parts in my PC are:
CPU: Intel i7 920
MotherBoard: i7 Gigabyte GA-EX58-UD5
Graphics: ATi Radeon 4890 1Gb
Hard Drive: Seagate Barracuda 7200.11 500gb
DVD Drive: ASUS DRW-2014S1T
RAM: Partiot PC3-12800 1600MHz 6GB kit
I'm not sure whether a 750W Power supply is enough or not is there a way of calculating it?
Thankyou
  • dead_sxc Jun 20, 2009
    Thankyou Very Much thedave108.
  • 4 Answers
750 Is PLENTY for your gear. Go hear and see. 750 can run 2 videos, 4 hard drives +
http://www.thermaltake.outervision.com/
Posted on Jun 20, 2009
What is the value of the resistor marked R338 in the power supply of Peavey pv 1500 2 x 750w power amp?
i have bit of the problem, i cannot find anywhere on this schematic resistor with 338 value, go to this page:
http://www.schematicsunlimited.com/p/peavey/peavey-pv1500-amplifier-schematic
i have another listing which is for pure power supply only:
http://exodus.poly.edu/~kurt/manuals/manuals/Other/POWER%20DESIGNS%20TB343A%20Instruction.pdf
this is giving me value, if i am correct, your resistor will be metal film 100ohm +/-1% 1w
you can re-calculate if this is correct value.
hope this will help you, do not forget to vote
Jan 26, 2015 | Peavey pv 1500 2 x 750w power amp
I recently purchased a new Radeon 7970 graphics card and installed in into my computer which currently is... --AMD Phenom II X4 965 Black -BIOSTAR TA790XE -600 Watt OCZ mod x stream-pro power supply...
Hi David,
Try removing and resetting the CMOS battery on your motherboard. Also, make sure that all connectors from power supply are plugged into the motherboard. There should be power for sys fan, CPU fan, etc.
Thanks,
E.
Sep 20, 2013 | Computers & Internet
Power Supply Dry Run Problem
You need to have the case's power switch plugged into the jumper pin header of the motherboard. Plug in the PSU into the 120 volt mains, enable the PSU via the switch (the one you turned on in the video) and then press the power switch on the computer CASE.
That should do it!
May 29, 2013 | Computers & Internet
9800 GTX+ PSU and motherboard
Yes, the 750W power supply is more than enough, and yes, that motherboard will support the 9800 GTX+.
Jul 22, 2009 | Acer Computers & Internet
Xps gen 4 desktop power supply upgrade possibility
Buy a generic case that will accept the power supply you need. Of course you will need to transfer everything from the old case to the new case.
Dec 05, 2008 | Computers & Internet
Dell Power supply NPS-460BB needing to upgrade
if its a laptop then no you can't i'm affraid, if its a desktop then you can
hope this helps
kind regards
Nov 19, 2008 | Dell - NPS-460BB-B (NPS460BBB) Power...
New build computer wont turn on (ASUS A8N32-SLI Deluxe Socket 939)
The ATX power supply needs to have pin16(PS_On#) to be connected to COM for it to work. When you press the power switch on the front panel of the computer, you are essentially making this connection. Check that the cable from the power supply to the motherboard is making good connection. You can verify operation of the power supply by shorting Pin16 to pin17 on the powersupply output, with a paper clip. Pin16 is usually a green wire and 17 is black. Hope this helps. -Vish
May 04, 2007 | ASUS A8N32-SLI Deluxe Motherboard
Thermaltake Toughpower 750-Watt Power Supply Logo
104 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
