Question about Sony Cyber-shot DSC-T9 Digital Camera
Flashing E61:10 My T9 flashes E61:10 with motoring sound anyone know how to fix or recommend a reasonable price repairer?-in Lonond?
Just remove the casing and spray 3m anti-static electronic cleaner stuff inside and around and dry with a cloth carefully. Then dry with a fan. Put casing back on. Works as good as new!
Posted on Aug 05, 2009
Electrolux E36DF76EPS Why does the lock light keep flashing ( note oven works normally )
Hello Thecarsons, thank you for your post!
I understand that the lock light on your Electrolux range keeps flashing and everything else is working properly. This could be a potential problem with your latch or control panel. I would recommend looking over the latch or strike for any visible damage. If you do not see any, I would suggest performing a reset on your range. You can reset your range by disconnecting the power cord or flipping the household circuit off for at least ten minutes. If that does not resolve your problem you may need to have a technician out to your home to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Jun 10, 2015 | Electrolux Ovens
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
Flashing AV signal on Pentax SLR
1) i recommend test the batteries that are o.k replace or recharge in full.
2) if this do not resolve the problem, the flash or the control circuit (Syscon)is faulty. you must go to the repair shop for fix it. Since this micro device electronic with the microcontroller, is NOT easy fix it , for anyone, you must know something about digital electronic and repair.
God bless you
Jul 21, 2012 | Pentax *ist D Digital Camera
Flashing screen on Toshiba 42HP66
Plasma sets use high voltage to produce their displays and it sounds very much like the HV supply is losing (or has lost) regulation likely due to the impending failure of a semiconductor.Check to see if Toshiba has any extended warranty on this since it could be a series problem.If there is none, ask for a price on a new or repaired supply on an exchange basis.
Dec 30, 2011 | Televison & Video
My playstation 3 turns on, powers up and then immediately turns off again, leaving a flashing red light. Does anybody know what the problem could be?
Hello there
From what you have said it sounds like you have the RLOD - RED LIGHT OF DEATH
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
Front panel green light on,not flashing,on/off light flashing,no picture
Hello there
From what you have said it sounds like you have the RED LIGHT ERROR this can be fixed
Many thanks
Peter Fix
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
It just shut off and now the red light is flashing. what is the problem do u know?
Hello there
From what you have said it sounds like you have the RED LIGHT OF DEATH ERROR
Many thanks
Peter Fix
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
All the lights flashing, then lights 1 and 4 flashing
Error 1 and 4 indicated an EEPROM / Set Up Error.In simple words, one or both PCB's on your washer are at Fault.Cheapest repair to this is to phone Hotpoint. They will do either a 5 year parts warranty repair, where you pay the labor charge or a fixed price parts and labor repair. Both are about the same price but you'd have to speak to Hotpoint for the latest prices.
I do know that to buy both boards would cost a lot more than the labor charge for Hotpoint.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 12, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Flashing red light no screen fujitsu plasma
I have no picture on my Plasma and I have a red and green flashing light. Does anyone know the problem and more importantly, can anyone recommend a fix?
Jun 16, 2009 | Fujitsu Plasmavision 42" TV
Red light flashing 5 times every 2 seconds
The 5 blink code in dicates a loss of video. There could be a number of reasons for this. I need to look up your specific model to get you the probable parts. Stay tuned...
Dan
Jul 29, 2008 | Sony KP-53HS10 TV
Sony Cyber-shot DSC-T9 Digital Camera Logo
166 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
