Question about Sewing Machines
Lost the black screw off ring on the bottom of the glass carafe that sits on the driving pegs of the motorized section. Can this be replaced?
  • 5 more comments
  • ubuntup Jun 23, 2009
    LOOK HERE! The problem is NOT a sewing machine.
    I have a DeLonghi 14 speed BLENDER. A machine that whips food into a smooth paste.
    Model KF1600EP.
    I have lost A Round BLACK RING PIECE THAT Connects the BLender Jar to the motor.
    Can this piece be replaced?????
  • ubuntup Jun 28, 2009
    LOOK HERE!!!
    I asked if the black ring linking the DeLonghi 14 speed BLENDER JAR to the motor could be replaced.
    The 'guru' replied: I think so,
    However NO INFORMATION AS TO WHERE I CAN ORDER THIS PIECE is provided. WHAT?????
    Please send this informtion by return email. This is becoming a charade. 2 weeks to wait for an address????
    Very annoyed and disgruntled Mr. John David Borgman
  • ubuntup Jun 29, 2009
    Thank you for the response requestion model number
    As follows:
    Delonghi 14 Speed Blender Model # KF1600EP
    Serial Number: 05308
    Please advise how to replace the black screw-off ring that connects the blender jar with the motor.
    As follows:
  • ubuntup Jun 30, 2009
    Thanks for your help. What I needed was the link you provided to see the blender parts diagram and to contact the company.
    Meanwhile the screw off ring for the blender mysteriously re appeared. so all is well.
    Apparently the re appearance of the missing part was worth the $10 charge!!!
    John David Borgman
    John David Borgman
    John David Borgman
  • Sewing Machines Master
  • 13,433 Answers
Yes I'm sure the screw can be replaced.
Posted on Jun 20, 2009
Concerning 1970s 830 Bernina. There is no motor sound..nothing. Are the carbon brushes in the pedal?
The 830 models varied so I'm not sure. My machine looks like this:
Bernina 830 sewing machine feet pedal accessory box table instruction...
If you scroll over to the photo of the motor, there is a white plug which pulls out. Underneath, there is a screw. The carbon brush may be there. However, some 830s had the speed switch on the machine (right above the knee control) and others have it in the foot pedal.
I found the following information in my computer files that may be helpful: Bernina 830 Motor Brush Replacement
My machine is actually a Bernina 830 (mechanical 34 years old) I need to know how to get the housing off the motor so my hubby can replace the brushes
Re: sewng machine motor housing
DISASSEMBLY TO INSPECT OR CHANGE BERNINA 830 MOTOR BRUSHES:
Remove the big plastic cover piece on the bottom of the machine with the single screw in the center.
Remove the machine's end panel by removing the single silver screw from underneath the bottom middle of the side panel. Pull the bottom of the side panel out and down to remove it. It comes off easily.
Remove the two screws under the motor assembly (silver screws with black washers).
Swivel the motor assembly enough to remove the belt.
There is a another plastic panel on the motor assembly over the motor itself. Remove the two phillips head screws to remove this panel.
At this point you can see the commutator and inspect the "business" ends of the brushes. (In our case, one brush was almost gone and there was nothing left of the second brush except the spring!)
You can then slide the motor out of the housing. I pushed on the motor pulley and pulled on the other end of the motor with pliers. The motor comes out rather easily, but be careful not to disturb the wires any more than necessary.
With the motor exposed, unscrew the caps over the brushes and remove the brushes.
Our motor's commutator looks significantly worn and the motor may need to be replaced.
FWIW, if your machine hasn't been oiled for a long time, you should probably take time to do that. When the old oil solidifies, it sticks the moving parts together. Forcing the motor to try to run the machine can damage the machine. Use fresh good quality sewing machine oil or (I use) liquid Tri-Flow Synthetic Lube and apply a couple drops every place metal rubs on metal. (Wiggle the handwheel and watch where things move.) Do NOT oil belts, synthetic gears, cams.
Oct 22, 2016 | Bernina Sewing Machines
How do I remove the metal case of my sewing machine so I can replace a belt?
A: You asked, "How do I remove the metal case of my sewing machine so i can replace a belt?" Without the specific Make and Model number it is impossible to give a specific answer, so with such a general question you can only get a general answer regarding Metal-Case machines (since that is the only information you provided in your question).
Many Metal-Case sewing machines usually have either:
(A) External Motors and External Drive-Belts, changing the belt is easy and intuitive.
(B) Internal Motors that are Internal Direct-Drive and have no Drive-Belts to change or adjust.
(C) Internal Motors and Internal Belt-Driven Hand-Wheels, and this is what I assume you have. To change the belt:
(1) Unplug the machine.
(2) Remove the Top-Panel (usually 2 or 3 screws need removal). Some machines (very few) have a pry-off top that has no screws, just internal spring-clips that hold onto nubbins under the lid.
(3) Remove the Left Side-Panel that fits around and under the Hand-Wheel (if it has a side panel; and it may be plastic, there should be 1 or 2 slot-head screws holding it in place. If it just has 1 screw it is generally centrally located; if 2, one may be high and the other low. A few machines also have interlocking tabs that fit into the body, that must be un-puzzeled to remove.
(4) Loosen the motor Drive-Belt Pulley to remove the old belt (it is usually a slotted set-screw or a small Allen Wrench (Hex).
If there is a Part Number on the old belt, use, or measure the old belt and/or use the Part Number to help match it to a new belt. If you have a manual, it may show the Drive-Belt Part Number; there are also Parts Lists for many machines. Less expensive generic parts are often just as good, as long as they are of the correct size, configuration and installed properly. Avoid the rubber-band type giant O-Rings to Drive machines, Belts are better *.
(5) Replace the new Drive-Belt and Drive-Belt Pulley, adjusting the belt tension so the motor can reach full speed without laboring. "A Twee-Bit Too-Loose" is better than being "Too-Tight"., but best to be just right, that is to allow the belt to deflect a little if pressed in the middle, yet tight enough so there is no slippage. A lugged belt (often Orange color, but sometimes Black) makes it much easier, since there is no slippage due to the lugs, and it can allow the machine to turn easier (with less resistance than * tight O-ring Drive-Belts) to sew better with less motor- bushing wear). "Assembly" is the reverse of "Disassembly".
Sincerely,
-- Amender (2016 FEB 23)
Jan 30, 2016 | Sewing Machines
How 2 fix Brother's CS-8060 bobbin auto winder to work?
Replacing the bobbin winder rubber ring.
  • The case halves are held together by 5 larger screws, one under the carry handle, obvious from the holes in the casing, plus one smaller screw up by the foot-raising lever.
  • There is also the final screw, which is a devil to find. You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
  • Once this tray is out you can see a small bar with a screw. Remove this screw and the 2 halves of the case will separate.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
  • Now you can carefully ease the ribbon-strip cable from the circuit board and move the case round to be able to access the screws that hold the circuit board. You do not need to pull out the other cables; just take a tad of care as you work.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
  • Take the opportunity to clear out any fluff and dust while you have the cases apart. Put ONE drop of oil in the center of the bobbin carrier rotating mechanism and one drop on any moving joints.
  • Replace the components/ ribbon cable in the reverse order, taking care not to drop the small screw! It is necessary to carefully line-up the hole into which it fits. It is surprising how easily the tray clips back into place, compared with the hassle you had getting it out.
I took both my CS 8080s apart last week to replace the drive rubbers. The first took nearly 1.5 hours, the next 1 hour as I knew what I was about.
Jun 17, 2014 | Brother CS-8060 Computerized Sewing...
Brother cs-80 winding bobbin makes whirring noise and doesn't wind
  • There is also the final screw, which is a devil to find. (see 3rd image)You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
  • Once this tray is out you can see a small bar with a screw. (see 2nd image)Remove this screw and the 2 halves of the case will separate.
I took both my CS 8080 apart last week to replace the drive rubber. It took nearly 1.5 hours along with the cleaning and lubing.
I am sorry the 3rd image is so small. It shows the screw to remove to access the arrowed screw in the second image
Feb 09, 2014 | Brother Sewing Machines
Spoolcase assembly
Do I understand right, you unscrewed two screws on the bobbin case holder and lifted it out? Underneath is a black plastic ring (inner guard ring) which sits inside the lower guard metal outer. I guess you undid the bobbincase to clear under it, I have seen machines with a lump of lint under turned into felt from being left so long. While its out, clean the underside and under the inner guard ring with your little brush, chech the bobbin case holder side too, there is a little groove on the side and sometimes tiny bits of thread will be caught in it. The trick is to turn the flywheel until the lower guard cutout open bit is facing 6 on a clock dial, ie closest to you. Now look at the inner guard ring, it has a flat edge cut off, turn it so the cut out faces about 7 on the clock and centred in the outer guard. Now you need to insert the bobbin case, it has a piece with two "beaks" on it, this is the front and these beaks need to sit between two metal parts in front of the outer ring which holds the bobbin case firmly. Put the front part in place and the whole case will fit in perfectly, just give it a little wiggle if it doesnt quite line up. Tighten the two shinny silver screws to fasten in place. There is a little black screw too but dont touch this, its a fine tension adjustment. Hope this assists you, if not post again andI will try to find a photo of the assembly.
May 20, 2013 | Elna Heirloom Edition 6005
CS-8060 feed dog
then your feed dog button is either come loose or is broken, it needs to be
serviced
Jan 18, 2012 | Brother CS-8060 Computerized Sewing...
How can I fix a drop-in bobbin
  1. Cleaning and oiling the machine
    • 1 Unfasten the top, bottom, side and handwheel covers, using a screwdriver. Set the covers aside.
    • 2 Remove the plate that covers the thread bobbin. If it is screwed in place, use a screwdriver. If it is held by a clip or magnet, use a small flathead screwdriver to pry up the plate.
    • 3 Thoroughly clean inside all the openings, using a vacuum with crevice attachment. Remove any stubborn lint, and use tweezers to take out any thread that is wound around the parts.
    • 4 Clean the teeth on the gears, using the tip of a round toothpick to loosen the grime. Vacuum to remove it.
    • 5 Lubricate all the moving parts. Use white lithium grease on the gears, and sewing machine oil on the other parts.
    • 6 Reassemble the machine and plug it in.
    Tightening or replacing the drive belt
    • 1 Remove the top cover, bottom cover and handwheel cover, using a screwdriver to take out the screws.
    • 2 Inspect the drive belt. If it is slack, use your screwdriver to loosen the screws that hold the motor in place, then follow step 4, below, to increase the belt's tension. If the belt is cracked or broken, get a replacement from your sewing machine supplier.
    • 3 Install the new belt. Loosen the motor-mounting screws, and shift the motor toward the handwheel so you can slip the belt over the parts.
    • 4 Shift the motor away from the handwheel to increase the belt's tension, then tighten the motor-mounting screws and check the tension. The belt should flex no more than 1/2 inch (12 mm). If it is too loose, increase the tension.
    • 5 Reinstall the covers and plug in the machine.
Oct 20, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
I cannot remove light cover on ceiling fan to replace globe
There are usually small screws around the outside of the globe that screw into a recess on the globe with a rubber ring around it to keep the screws from hitting the glass.
Dec 31, 2009 | Sewing Machines
Elna 700
If your machine did not come with a little screw driver, you will need to purchase a r flat tip screw driver. Usually, you can find small screw drivers in an eye glass kits too. Take your needle, your foot, bobbin, etc. all moving parts off and set aside. Then use your screw driver to remove the bottom plate. Sometimes it could be sitting right there you might can turn your machine upside down and you should here where it's at without having to disassemble the whole bobbing casing. I hope this was helpful.
Dec 11, 2017 | Elna 2007 Mechanical Sewing Machine
Sewng machine motor housing
Our motor's commutator looks significantly worn and the motor may need to be replaced. If you find a source for the brushes or a replacment motor, please let me know! Thanks, John john@jldnet.com
Jan 27, 2008 | Bernina Activa 130
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
