The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
SOURCE: I have a sony DAV DZ230 home theatre system
Push Power Protect is error sign when unit got problem in Power Amplifier section.
Let me know if you have electronics repair experience to help you further as I have all necessary info and schematics of DAV-DZ230 home theater system.
SOURCE: why does push power protector keeps flashing in
This is an error massage and comes when home theater got some internal problem specially in amplifier output section that can have defective output IC etc.
It is not user level repair and requires qualified tech for fix.
Thanks.
SOURCE: "Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
SOURCE: SIR MY DAV-DZ110 HOME THEATER WAS FLASHING "PUSH
ola tengo un problema esk yo tengo el sony dav-dz110 cinema esk cuando enciendo me sale push power protector no se por k sale esto si alguien me ayuda se lo agraseria
