Question about Gigabyte GA-8I845GVM-RZ Motherboard
Reset BIOS How to reset BIOS in Gigabyte motherboard ....
    President:
  • 987 Answers
In order to reset BIOS you need to remove the CMOS battery located on the motherboard and re insert again
Posted on Jun 20, 2009
    Problem Solver:
  • 7 Answers
There is also a jumper switch on the motherboard that is called reset cmos. But I prefer the battery option. remember to wait about 5-10 minutes before replacing the battery
Posted on Jun 28, 2009
2 Suggested Answers
  • 434 Answers
SOURCE: My Gigabyte GA-G31M-ES2L Motherboard BIOS is
Try this link:
http://bios-repair.co.uk/bios/bsrecover.htm
Posted on Feb 11, 2011
How do i reset the bios to default settings on a gigabyte GA-790FXTA-UD5 motherboard using jumper on motherboard?
If the HDD is new to the system let the system try to Boot then reboot and go back into the BIOS it should show in the BIOS but you may have to change the HDD priority before it will let you select it in the Boot menue.
The Bios can be reset with the directions posted on the Gigabyte Forum...
http://forum.giga-byte.co.uk/index.php?topic=15589.0
If you need further help, reach me via phone at https://www.6ya.com/expert/john_411a7faba7ce8217
Oct 19, 2016 | Gigabyte GA-790FXTA-UD5 AM3 AMD 790FX SATA...
How to reset BIOS on Gigabyte GA-H55M-UD2H. Here's my story. A long while ago, I set a password to my BIOS. But then almost 11 months later, trying to use it, I can't remember the password. Is...
check your motherboard manual fo CMOS reset jumper location on you motherboard, and follow the instructions on resetting to defaults. Keep in mind that any customisations implemented by you in bios will be lost, so you will need to do them again.
Hope that helps
Cheers from NZ
Jun 19, 2011 | Gigabyte Computers & Internet
I have updated my gigabyte 81845GVM-RZ bios. Now it doesn't start at all.
Unplugthe computer and depending on your experience locate a silver circle alittle smaller then a quarter. remove this battery for a few minutes.This will reset your bios to default and should get you started up.Recheck your bios update compatibility and make sure its correct.
BIOS Version 8.0 download it.
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ProductID=1767
Say"Thanks" by clicking the thumb icon in the post that helped you.Pleaseclick "YES" in solution that solves your problem as "was this helpful?"
Apr 20, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
HOW I CAN RESET MY GIGABYTE G31 MOTHERBOARD BIOS PASSWORD?
Remove the CMOS battery in the motherboard for some time and then plug it again the bios will be reset to factory defaults with no password. CMOS battery is like a coin in the motherboard with positive sign (+) in the upper side.
OR
In the motherboard there is a bios reset jumper, it has three metal with two of them was use by the jumpers as the default, just move the jumper place it occupying the third metal point leaving the first. wait for about 1 min then return to the original setting occupying the 1st point, turn the unit on and CMOS will be cleared off.
Feb 12, 2011 | Gigabyte Matx Intel G31 775 DDR2-800...
I have a Gigabyte GA-7N400-L motherboard CPU problem
dit you try a bios update?Some motherboard needs a bios update for a newer cpu.
Jan 17, 2010 | Gigabyte GA-7N400-L Motherboard
BIOS problem
Turn of computer re start and reset the BIOS through the motherboard BIOS Reset jumpers
Aug 08, 2008 | Gigabyte GA-6WMM7 Motherboard
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Gigabyte GA-8I845GVM-RZ Motherboard Logo
1,228 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
