My tedelex ec21e09g tv lost its colour its greenish n grey people
Check its video output stage circuit board; for any loose solder terminals. This card can be located at the back of the picture tube, will directly plugged to its back. Absence of blue is the reason.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
SOURCE: Tedelex colour TV
first check the fuse in the plug.if its ok then the fuse in side the tv might have blown,if you are going to check the fuse in side the tv your self PLEASE make sure that the tv is NOT plug into the mains and be very careful that you do not touch any of the circuit boards as you will/might get a electric shock..the fuse might be a 20mm glass type,inside the fuse you should see a piece of wire if this is broken then that is the fault,if you cannot see the wire then you will need a meter to check the fuse. if you have no meter to check the fuse then take the fuse to a tv shop to check..hope this will get the tv working,if not then im afraid the tv will have to be taken in for repair..all the best..Lee Bruce.
