Question about Seagate Barracuda 7200.7 40 GB Hard Drive
My computer running xp doesnt see my old comps drives that ran 98
I had a comp running windows 98 and was having a hard time booting it up so i decided to take the drives and put them in my new comp running windows xp. my current computer has 3 drives one 232 system disk and two more in raid array. I had to use an ide cable to hook up the two drives from my old computer. the found new hardware wizard found the drives when i added them but when i open my compute icon it doesn't show the added drives. however when i run my disk eraser program it finds them but shows them as unformatted drives. i have tried making them slaves and even setting one to master and one to slave. but no matter what i do my comp doesnt see them. i want to get the data off of them and am not sure how to do this. my xp files are ntsf is 98 a diferant file format? how can i get the data from the old drives to my new drives?
  • 499 Answers
Hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Posted on Jun 20, 2009
My comp doesnt instal xp.a hard disk error appear after loading files.systemroot>system32>config.i had instaled 2 copies of the said xp sadly i mistakenly deleted part of the xp.help coz my comp is...
you need to do this on a brand new low level formatted, and high level formatted hard drive. you must have the install disk, and a internet connection, and a properly running system available to work along side.
You can reformat this old drive; however, personally, I wouldn't bet on using it. hard drives are cheap these days. let me know.
Sep 16, 2012 | Computers & Internet
My laptops slow need to make it better
Hello
Installing windows xp, will only slow down your computer, as windows xp use much more resources than 98.
Also, we are not allowed to provide customers with piracy links.
Regards
Andrea
May 25, 2010 | ASUS L 8400B Notebook
Want to comp re format hard drive and then install
well if u have windows 7 disc, then u can use that to boot the computer from the disc n then it will give u option to format the hard drive and install the new os.
u will have to boot the computer from the windows 7 bootable disc.
Nov 01, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
My cisnet computer keep reading disk errors.i tying to install window xp. it also system window 32 problems. is a missing files. how do you fix it?
u need to format using a windows 98 sec boot disc. place the floppy in to the comp. switch on the comp. let the disc run, making sure your bios is set to boot floppy first. when disc is finished setting type fdisk then when finished delete drive by pressing 4 .add drive when finished by pressing 1 and following the insturctions. when finished press crtl+alt+del let the comp, reboot the when the disk as finished loading type format c: press yes let it run press crtl +alt+del again then take out floppy disc and put in winpx . as this sounds like you have a virus in your registery
Aug 03, 2009 | SimpleTech 320GB SimpleDrive External by...
Win98 hds in win xp dont show other program says not formatted
you will need to revert back to the master/slave setting.  As slave/slave neither disk will be the main controller. Try reverse the master disk to the slave, and the slave to master, as it may be that the controller has a fault which is why you were having the original win98 problem.  Let me know how you get on
Jun 20, 2009 | Computers & Internet
How do i transfer data from windows 98 formatted drives 2 xp ones
Set up your old drive as a slave and copy the data. Good luck.
Jun 19, 2009 | Computers & Internet
NTLDR missing on changing harddisk connection
put the xp bootable disk in computer and boot from it, choose repair option. it will slove your problem.
Feb 24, 2009 | Microsoft Windows XP Professional With...
Formating hard disk
IF the old PC motherboard will recognize the drive while booting up, Windows 98 will also see the drive after boot-up. You may have to reformat the drive into smaller partitions.
All you have to do is physically install the drive in your old computer and attempt to boot. After the computer boots up, if the drive does not show up shut down and put the drive back in your old computer. Use the manufacturer's partitioning software available on their website to change the drive from one 250 Gb partitions to five 50 Gb partitions.
Feb 15, 2009 | LaCie (300728U) 250 GB Hard Drive
HD installed with XP in Giga MB,not booting up in the originalP3
it is impossible or else you reload the hd on the motherboard
Jan 21, 2009 | Computers & Internet
Trying to boot from a hd from my old comp
MS Windows XP when installed to an HD will "marry" itself to the hardware of the original computer specifically the motherboard. Transplanting the HD to another PC with a different motherboard will result in a cycling blue screen of death or protective message requiring that you reboot. Running in Safe Mode will not also be allowed.
You need to re-install your OS (boot from CD) but choose the 2nd repair option rather than a new/clean install or the first repair option if you want to preserve your other applications as well as your settings/configuration. Doing this will allow the OS to install the new device drivers and delete the old ones.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
God luck and kind regards.
Jan 13, 2008 | Computers & Internet
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
93 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
