Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
My tromm lg 2077cw has decided to stop spinning. I read the problem solver on the website, but it did not fix the problem (unplugged the machine for 30 minutes - actually drained the water out, and try to run with a no spin cycle, but the spin lights up and it tries to spin). The unit is only 3 years old - it tries to spin and actually will make a revolution or so then just keeps 'nudging' the drum, trying to turn but not able to. help.
    President:
  • 632 Answers
Error code means motor overload...it just confirm my diagnosis ma'am...
Posted on Jun 20, 2009
  • 3 Answers
Look at the beld is on this place
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Drum does not spin
We have an LG TROMM with the same problem, 3 years old as well. We bought the extended warranty (Huge waste of $$$$).  So far they have determined it is not the motor or either of the control boards.  We think it might be a relay switch or possibly the brake.  Good luck with yours, we just went out and bought a new washer.
Jun 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG TROMM reads a blinking LE message
motor locked...not and easy fix but if you want to give it a go let me know...onthejob
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Trap clear on lg tromm. still no spinning and/or draining; pse ad
OE code should appear. I've been able to re-start after unplugging the machine for ten minutes and then re-plug and it did clear the code and spin out but I'm back to the same problem and unplugging isn't working anymore. I'm wondering now if the issue maybe the machine isn't level. Well, something I'm now going to check. Good luck.
Dec 27, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Nov 17, 2007 | LG WM1814CW Front Load Washer
Washing Machines Logo
298 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
