Computers & Internet Logo
A
Anonymous Posted on Apr 23, 2014
X44h split screen - ASUS Computers & Internet
divvy_ni
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Apr 24, 2014
divvy_ni
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
1077
Points
11
Do you mean cracked screen?
If so to replace it:
take off the two screw caps on the bottom corners of the screen bezel and take out the screws. Take the bezel off by pulling it away from the inside around the border of the screen, careful not to snap it.
Once that is removed you can pull away the back cover.
check the code on the back of the LCD screen and order a replacement of the same model.
Unscrew the screws at the sides of the screen and disconnect the ribbon very carefully not to tear it or you'll have to pay to replace that also.
Search youtube for videos on replacing laptop LCD's so you have a clear mental image of how to go about this prior to the attempt if it's something you have never done before
I have a iPad Pro and my screen has changed from a full screen to one that us 1/2 full what is my problem
How to Turn Off Split Screen on iPad Split View is enabled by default on the iPad. To utilize the feature, you can drag an app from your dock to the right or left edge of your screen to open the app on a portion of the screen. If you have multiple apps open and want to close one without turning off the Split Screen or Multitasking functions in settings, you can return to a full-screen view of a single app by dragging the edge of the app you want to remove to the edge of the screen.
If, however, by "getting rid of split screen on iPad" you mean turning the feature off completely, that's something you can do in Settings. To turn off split screen on the iPad:
  • Open the Settings app on your iPad.
  • Tap General.
  • Select Multitasking & Dock.
  • Toggle off Allow Multiple Apps.
How to Get Rid of Split Screen in Safari on iPad Using split screen in Safari on iPad was a new multitasking feature for iOS 10 that continues in iOS 12. This allows you to open two separate Safari web pages simultaneously on your iPad. To start, open Safari on the iPad. You can then open a second Safari tab in split screen in one of four ways:
  • Tap and hold a link; select Open in Split View.
  • Tap Command+N on an external hardware keyboard to invoke Split View.
  • Drag a tab from its space to either the left or right side of the screen to open it in split screen.
  • Tap and hold the icon that opens your tabs view in Safari. It looks like two overlapping squares. When you tap and hold, options will pop-up. Select Open Split View.
But what if you want to get rid of split screen in Safari? What if you're done using the two tabs-how do you turn split screen on the iPad off? To close split screen in Safari on your iPad, you can do one of the following things:
  • Drag the tab(s) from one of the screens to the other. Once the last tab has been dragged to the opposite side, Safari will return to full screen, which will turn off split screen.
  • Or, you can tap and hold the tabs icon, which looks like two overlapping squares. Then select Merge All Tabs. This will merge all your Safari tabs back into a single window, which gets rid of split screen.
We have xbox360 it's hooked up to sansui sledvd244 how do i get split screen so there can 2 players please help
Minecraft Xbox 360 is a multiplayer game by default. Players can join online or locally via connected controllers. Split screen is a way to play multiplayer on the same console. To play split screen, the Xbox must be outputting a resolution of 720p or higher.
you must have an HD TV for split screen. Connect Xbox to tv with an HDMI cable. Start mine craft when you've logged on with your first controller enter your desired world then pause the game. Turn on and sync your other controllers if they haven't been connected before.Log in those controllers and press Resume Game.
  • Your television screen should be split into two or four parts depending on how many controllers are connected.
My laptop is randomly shutting down.
check laptop randomly shdn:
software
1) renew windows system
2) clear virus
hardware
1) change adapter or battery
2) check or soldering DC lack
3) over heating, clean cpu fan dust
4) hard disk o sector issue, change HDD
I can find no way to turn off the touchpad and it's screwing up all my papers
I am assuming that you are accidently bumping your touchpad while typing. There are several programs out there to correct this issue, but the easiest one i have found is called TouchFreeze. It disables the touchpad whenever your are typing.
D/L link: http://code.google.com/p/touchfreeze/downloads/detail?name=TouchFreeze-1.1.0.msi
My laptop suddenly black out when I use broadband...
i have been getting attacked by my own isp. trying to open ports and take control of my system remotely my antivirus software is the only thing that stops them
How can i increase shut down speed of x44h laptop
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when you initiate.
You can also use a 3rd party application like TuneUp Utilities.
1helpful
How do i enable the webcam on asus x44h laptop
go to your control panel look for display then web cam and enable
Split screen
Hi!
the word split-screen usually applies to microsoft office products. Click on Windows > Split on microsoft excel. Other than that, if you are referring to actually splitting the desktop. So you can have two desktops, then use VMWARE.... try googling it. It can manage multiple desktops.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
