Can you tell us what error 6 is as displayed on Kleenmaid KFL1600 front loading washing machine. We have the manual and it is not listed. Many thanks
Hi I've got a KFL1600 with error 6 too - I fixed this once by cleaning the filter, but now it's come up again and the filter is clean. Not sure if it's related but the door has stopped unlocking too and we have to open it by pulling the little tag in the filter door. Very reticent to get it repaired as everyone says that these machines are a nightmare and costly.
Posted on Jul 22, 2010
  • ian6839 Jul 22, 2010
    Found some more info on a couple of sites. Error 6 means that means that the machine is not heating up enough in the time available. which can be due to either:
    1. The machine is overloaded and is automatically taking in more water than it can heat up in the time available. If you are using a gentle or synthetic cycle then it requires more water so they recommend that on those cycles the machine should only have a half load (3kg).
    2. The heater is broken and the water is no heating up at all
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Hi I have this error displayed in my machine. Can you tell me what causes this? Could it be because we use too much washing powder? Thanks
You did not post the error BUT if it is a front load machine you must use detergent that says "He" That detergent wont produce a bunch of suds.
Jan 10, 2016 | Washing Machines
Drum wont spin in washing mode. it only works for rinsing and dry spinning. sharp ES-M38 washing machine
Because i know nothing about Sharp washers could you tell me if it's front loading or top loading? Is it less than 6 years old? Does it give any error codes? Thanks.
Jan 20, 2013 | Kenmore Washing Machines
What causes "Error 4" to
Hi, googled this problem myself and found this page. Doesn't help much though. Will still have to get someone out to look at it.
http://kleenmaid-appliances.com.au/TSPM/WM/Kleenmaid/KFL1600_Fault_Codes%2040220415.pdf
Good luck, we'll need it now our warranties are useless.
Dec 04, 2010 | Washing Machines
LG front loader washing machine UE error displayed
Imbalance error
Causes:
Load too small
Appliance is tilted
Laundry gathered to one side
Non-distributable thangs are put into washer.
Here is the WM2277 Service Tech Manual
You will find a list of fault codes on page 17 of it.
Note: This is is not a user manual it is the repair manual.
I have assembled some common problems and the solutions on the washer HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 17, 2010 | LG WM-2277HW Front Load Washer
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
KFL1600 - stops with Error 7.
If you unplug the machine when it stalls, that should reset the controller to allow release of the door. Does the pump run when it is supposed to? If ok, check the drain coupling at the bottom of the outer tub. If you pull the drain hose loose at the tub, water should run out (if water is in it). If not, there may be a stray sock or similar that is blocking the drain opening. Hopefully, there may be an access plate nearby that allows cleaning of the port. Otherwise, the machine will need to be torn down completely to access the port. (BIG job!) If you lay the drain hose down at floor level, an open drain system will allow gravity draining of the machine which would point to a defective or inoperative pump.
Nov 15, 2009 | Washing Machines
Kleenmaid kfl1600 front loader, does not start
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2009 | Washing Machines
Washing Machines Logo
214 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
