Question about Lexmark X2470 All-In-One InkJet Printer
Ink low massege after refill
I refilled my canon ip 1200 my cartridge but ink level still low. "Help me "
    President:
  • 828 Answers
Dont worry its always like that, sometimes the refill ink from tis design are normally recognizing its slow but after all when you keep using that and print more... it will not prompt again...
Posted on Jun 20, 2009
I was riffil ink cartridge on my canon ip 2772 printer but ink level is not build up . So I need solution how to reset ink level on canon ip2772 printer
After refilling your ink, it may prompt your ink very low... but it is nature there is no problem and effect for that... don worry! All the Canon printer prompt like that.... thanks
Aug 28, 2011 | Canon iP2700 Inkjet Photo Printer
Does ink refile is possible in canon ip 2770 printer?
Yes, Canon ink cartridges can be refilled. Most Canon cartridges can be refilled up to 12 times. Canon cartridges consist of a sponge and an open ink reservoir, so they can be refilled using a syringe.
Nov 14, 2010 | Office Equipment & Supplies
I have refilled my main black ink cartridge on my canon pixma ip 3600, my printer won't acknowledge the refilled cartridge, is there anything I can do about this?
This is because the ink cartridges has a memory chip.It monitor ink levels.Press and hold the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Replaced ink cartridge and it still says low ink
There is no way to reset the ink levels on this type of cartridge. Therefore, your printer will always think refills are empty. You can choose on the dialogue box to "ignore ink levels" and run the cartridge until it is empty. This is just one thing you will need to deal with on refills of this cartridge type.
Oct 18, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Refilled ink cartridges not recognizby printer.
I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
My cannon printer pixma ip1800 cannot detect ink pls help me...
If after you install the cartridge you get a yellow light and error message:
“The following may have run out of color. The function for
detecting the remaining ink level will be disabled since the
ink level cannot be correctly detected. If you want to
continue printing with out this function, press the printer’s
start button. Canon recommends using new genuine Canon
cartridges in order to obtain optimum quality.”
Do not click “cancel printing”. Press printer start button
to start printing. This action will bypass the ink level
detection from the recycled cartridge. It will not damage the
printer! With a recycled cartridge this action needs to be
done one time.
A full recycled cartridge ink level may not display correctly.
It may show empty.
If you want to check the ink level, you can do a “Nozzle
check” by follow the directions below:
Go to menu File select print click on “Property” click
on “Maintenance”
Click on “Nozzle check” to print out the color check.
Click on “Cartridge Alignment” to align the cartridge.
See pictures for above process at Inktelligent ip 1800 topic
Also the refills refered to above are at the IP 1800 inkfilling page
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Lexmark X2470 All-In-One InkJet Printer Logo
138 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
