Question about Ergomotion Furniture
The bed is stuck with head up can I manually lower the bed
I need to manually lower my bed
    Master:
  • 539 Answers
We have a Tempur-pedic. Each side is controlled by its own remote. It also has battery backup for each side (head and foot) in case the power goes out. We simply push a little button on the battery controlled box on whichever side needs lowered. It works to lower them, but they cannot be raised in a power outage. If you don't have something like that, or a manual crank or something, I suggest you call the company and ask THEM what to do. If it's stuck with the power still on, then even more reason to call the company.
Posted on Aug 12, 2016
  • Joe Ball
    Joe Ball Aug 13, 2016
    You also might try unplugging the bed for about 2-3 minutes, then plugging it back up. Many electronic devices will "reset" when that is done. Good luck!
My mother in law has a craftmatic bed and the bed will not lower. The head and feet raise and lower, but the whole bed is stuck in the up position.Is there a way to manually lower it?
Only if you can get to the motor and take off the cover and get a spanner or socket and rotate it till the bed lowers if possible but it can be dangerous
Dec 23, 2016 | Furniture
Motor broken. How can I lower head of bed?
Depending upon the design, it might be possible to disconnect or remove the motor to allow the head to lower.
Feb 19, 2016 | Invacare 5890IVC Home Care Bed
NEED OPERATING MANUAL FOR INVACARE TURN 2 PLUS MATTRESS PUMP
  1. Use the (M) Auto-Firm Button. Press the Auto-Firm Button to engage auto firm. The Mattress will become firm for nursing procedures. An indicator lights to notify the bed is in Auto-Firm mode. A timer will cancel auto firm in 30 Minutes. Should the nurse be called away, an unattended patient will not be left on a firm surface.
  2. Set the patient weight with the Weight selection buttons (G).
  3. Press the "Center" static Turning Mode button (I).
  4. Place the patient on the bed.
  5. Center the patient on the bed from side-to-side and head-to-foot.
  6. Use a regular pillow under the head for comfort and to prevent the head from rolling excessively.
  7. Raise side rails.
  8. Press the desired Turning Mode button (O).
  9. Press the Full Turn Range button (J).
  10. Set the Turn Interval time with the up/down buttons (L).
  11. If the patient feels the bed is too soft/hard press the up/down Comfort Range buttons accordingly (H).
Jan 09, 2013 | Invacare Air Flotation Mattress Overlay...
Ultramatic bed problem - bed will not raise either head or feet - does not move at all. Received replacement remote from company but no different. Lights on remote do not stay on - only when press a button...
Had same problem with my husbands moms bed. Found out that it ended up being a stripped plastic piece that the screw uses to raise and lower the bed. Because its stripped the screws don't have anything to grip on again to raise or lower bed. Piece needs replacing, but not sure where to get them.
Jan 12, 2011 | Minicraft Models Full Electric Bed -...
Electric control button raises the head of the Tuffcare hospital bed but will not lower it. It doesn't even make a clicking sound. All other functions are working through the control mechanism. Is there...
The problem you are describing happens quite often and there are several solutions.
1. The manufacturer sometimes supplies a manual crank that fits in the end of the motor to manually turn the motor and lower the bed. This crank is usually lost or misplaced (look for it on the bed frame). With the weight of the mattress and person off of the head you may be able to use a pair of pliers or other tool to carefully turn the motor shaft.
2. There is a bolt and nut at the end of the head motor shaft or a hitch pin and bolt. Remove this bolt at the end of the motor shaft where it attaches to the head frame and the head frame will drop to level.
3. Fixing the hand control usually involves taking the two halves apart and bypassing the push-button switch by shorting across the head down switch. This is the best way to diagnose a bad hand control. This is the most difficult solution for the average end user. You ultimately will purchase a new hand control anyway so this may be a viable solution. The hand control gets the most use and abuse and is usually the faulty part.
You may have a bad relay on the junction box control board where all the motors and hand control are plugged in. If the motor runs in one direction, the motor is OK. If you have the micro-switch style 6 button switch hand control you may be able to clean the switches by spraying contact cleaner is the switches and pushing them several times. Check the hand control plug for bent or bad pins at the control board junction box. The hand control pendant runs about $100 and the junction box controller is about $400. Hope this helps.
Nov 27, 2010 | Health & Beauty
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 | Baby Gear
CONVERTING TO TODDLER BED
i found this on the simplicity website, hope it helps. i got mine done i minutes!!!!
Remove Drop side.
Lower drop side. Push in on the tabs at the
bottom of both lower tracks to slide the drop
side down off the tracks as shown.
Position Mattress Support.
Mattress support must be in the lowest
position. If not, use the allen wrench to
remove bolts. Lower support into position
and re-attach to headboard.
Remove upper and lower tracks.
Aug 29, 2007 | Simplicity for Children Ellis 4 in 1 Sleep...
Furniture Logo
909 people viewed this question
Top Ergomotion Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Ergomotion Furniture Expert? Answer questions, earn points and help others
