Question about Sony Bravia KDL-32V4000 32 in. LCD TV
Negative picture with white haze? How do repair?
Check and replace damaged component/s at its T'Con board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 23, 2014 | Sony Bravia KDL-32V4000 32 in. LCD TV
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Haze cloud picture that cut people head off...
the picture sounds like its blooming, you must turn down the screen control on the back of the fly-back transformer, or the transformer has gone defective more likely and needs replacing
Jan 27, 2010 | Televison & Video
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
Nov 11, 2009 | Philips 43PP9202 43" Rear Projection...
White haze on projection
If your TV is a philips magnavox its most likely the CRT fluid is cloudy and should be replaced.
Got to www.TvRepairKits.com for a kit + instructions.
Jun 20, 2009 | Televison & Video
Green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Aug 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Blue haze on screen
blue haze on both sides of samsung plasma screen when goes dark or bright pictures. white lines on football ground appear blue???
Jul 06, 2008 | LG Televison & Video
Yellow corners on 56" RCA Rear Projection TV
possibly cleaning of the lens and the mirror might improve the picture. it could be what is termed a glycol or fliuid issue. dirty glycol will cause this yellow halo effect. the glycol came be changed a rather expensive and evovled repair i think
Jan 15, 2008 | RCA P46810LV 46" Rear Projection...
Zenith D60WLCD with blue haze over entire picture
throw the set away!the part required to repair the set is the optical engine.Zenith made alot of these sets with defective engine assemblies in wich the lcd filters burn,which cannot be replaced.The labor is also silly.Theunitrequires a complete teardown for replacment.You could buy a very nice new set for the repair bill
Feb 20, 2007 | Zenith D60WLCD 60" Rear Projection...
Sony Bravia KDL-32V4000 32 in. LCD TV Logo
16 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
