Question about Baofeng BF-888 S UHF 400-470 MHz Portable Handheld 2-way Ham Radio
Channel voice announcement
! Greetings., I have a problem with a radius boafeg bf888s, auxiliary audio advertising channels repeating freezes when receiving the communication, I do to remove that function? thanks for the help.
    Sergeant:
  • 435 Answers
Go into the programming software, settings & see if there is an option, if not it sounds like the radio is on its last leg
or at least try to a factory reset
Posted on Dec 28, 2014
We get a picture but no sound on any channels. Checked to make sure mute is not on. Any suggestions?
Check settings,
Likely
menu,
  • settings
    • audio
      • SAP if on turn off
Second audio program (SAP), also known as secondary audio programming, is an auxiliary audio channel for analog television that can be broadcast or transmitted both over-the-air and by cable television.
Hope this helps?
Jul 02, 2017 | Televison & Video
How do I connect a Sony xplod 1000 watt 2 channel amp to 1 10" dual 4 ohm voice coil 1500 watt planet audio subwoofer?
Connect one voice coil to one channel of the amp. Repeat with the other voice coil. Do not bridge the amp as your only choices would be series which would be an 8 ohm final load and cuts the amp power in half or parallel wiring which results in a 2 ohm load and very few Sony amps currently made can handle being bridged to a 2 ohm load.
Aug 28, 2016 | Sony Car Audio & Video
When listening to FM radio works well but when piece ends the announcer is muted - same with news, ads etc. Maybe i pressed the wrong button?
If you have it in a surround mode, make sure there is a center channel speaker hooked up. Most voice tracks will come through the center channel
Jan 05, 2016 | Denon Avr-391 Av Home Theater Receiver
I bought walkie talkies with 56 km radius and yet we are lucky to reach each other after approx. 1 mile,any idea why we don't get the range
You do not mention the particular model of Motorola, so this answer will be generic in nature. Some Motorola TalkAbout radios have been factory programmed with a few GMRS repeater frequencies. These channels require the use of a repeater tower, which will 'repeat' what you say over a greater distance. It is possible you have this type of radio. Check your user guide, and then set your radio to the appropriate channel for the repeater in your area.
Radio-to-radio without the use of a repeater you can expect up to 2 miles line-of-sight out of most handheld radios. This distance is reduced by obstacles such as buildings, trees, etc. inbetween the radios. It can also be reduced if you do not hold the antenna of the radio perpendicular to the ground.
Best regards.
Jan 19, 2012 | Motorola Walkie Talkies 2-Way Radio
A channel speakers not working on this unit - every other channel works (center, rear and B channel) . All connection have been checked.
The problem is the jumpers in preout front amp in, is where you connect an equalizer or auxiliary amp.You most connect the jumpers if you didnt use the equalizer or the A channel didnt work.
Dec 28, 2009 | Onkyo TX-DS777
How to get the aux channel on
Some tv's you have to go to before (channel down)channel 2, other tv's have a separate auxiliary channel button access. I have one tv that has a button labeled tv/video on front that does this; I have another one where it has 2 Auxiliary channels (for front input/rear input), I have to access these from channel up, channel down (my tv is always on channel 3)
Hope this helps!
Dec 07, 2009 | Cell Phones
Bleed over to other channels
When you make an announcement, It wil overide other normal traffic, Announcements take priority. Assuming you are useing a 6809 controller. Look at the announcement talkgroup, with your RSS or use CAS to look at the 6809.
Good Luck., Bill
Aug 27, 2009 | Radio Communications
I do not hear any music through my 10" M Audio Subs (M Audio Sound System)
If you know how to use a multimeter, you can test the amp this way:
-unhook the subs
-hook up a cheapie speaker you know for sure works to one of the channels
-unhook the audio inputs
-turn the amp on
-set your meter to VDC
-put the positive probe on the inside of the input connector, being sure you make contact with th inner contact
-take the negative probe and tap it on the outside of the connector
What you are doing is sending a low voltage (replicating an audio signal) into the amp audio circuit and allowing the amp to amplify it. If the amp makes the speaker pop each time you strike the probe, the amp is working.
You mentioned you need a 4 channel amplifier make the two, dual voice coil subs operate. The is not true and by hooking them up like that, there's a chance of damaging the subs. The reason is that the dual voice coils are interwoven and they have to get electrically identical signals or they fight against each other. The can mechanically fail, then, electrically fail, then even damage the amp too.
Nov 21, 2007 | Nakamichi PA-504 Car Audio Amplifier
My coby dvd 925
Coby dvd plays background music and all previews( music and voices ) but the actual movie we cannot hear voices only back voices and music can be heard.
Ray
raybuhr@yahoo.com 469-438-3979
Nov 19, 2007 | Coby DVD-925 System
Baofeng BF-888 S UHF 400-470 MHz Portable Handheld 2-way Ham Radio Logo
87 people viewed this question
Top Baofeng Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Baofeng Radio Communication Expert? Answer questions, earn points and help others
