Question about Star Micronics TSP650 TSP654 POS Network Thermal Receipt Printer
Printer offline printer has gone offline. how do i turn it back to "ready"?
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Printer offline wont print cant get back online
Step 1:
b. Click Printer.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Jan 12, 2014 | Canon PIXMA MX712 Wireless Inkjet Office...
Printer offline
Depends on your OS you need find "printer and faxes" or "printer options on the hardware.
  • Open the Start menu and click on the "Devices and Printers" icon. This will open a window with a list of the printers currently set up on your computer.
  • Double-click on the icon of the printer you want to change to online. The status of the printer will be shown as either "Printer: Ready" or "Printer: Offline."
  • Click on "Printer: Offline" and the Printer menu will appear. Click on "Printer" in the menu bar and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 12, 2013 | Office Equipment & Supplies
My printer says it is offline but the status monitor at the bottom of the screen says its ready... but will not print.. whats going on?
I've been suffering the same problem, but I think I havefound a solution. I have a MFC9320CW. It was showing 'ready' on the computer,but 'offline' on the Status Monitor.
My printer is set up to go to sleep after 5mins. I thought this was a problem,as initially it looked like it was in a coma, but it turns out it's ok.
I installed the software on my desktop (windows7) and after a bit of time thestatus monitor turned from offline to sleep. From here you can go into the(CC3) ControlCentre3 ->Device settings -> Remote setup and enter thepassword = access. Please note if the status monitor is showing offline youwill get an error message. A new window opens up. I went down to -> WLAN-> TCP/IP and then I changed the IP address, subnet mask and IP gatewaysettings, I also changed IPv6 to enabled. I applied these settings and then theprinter appeared to work as I expected it to.
I got the IP address etc from the printout I got when I initially set up theprinter.
I've been able to scan through the CC3 at my desktop; from the printer and thescan has gone to the desktop; and also from Adobe Acrobat8 at my desktop. I then set up a laptop (vista), first off I uninstalled allthe Brother software I had put on it as I'd managed to put the software onseveral times. When I installed the new software I chose the option MFL-Prowithout paperport11. When the status monitor opened and it was in the sleepmode I went to the CC3 -> Device settings -> WLAN and found all thesettings had been adjusted to those I had set for the printer at the desktop. I've now gone through installing it on a second laptop (XP).Again uninstalled previous attempts, then reinstalled MFL-Pro without paperport11 and this too is now working. So, if need be uninstall then install the software again.When you get the status monitor showing sleep/ready go into the ControlCentre3,change the settings as above, then all should be well. Since changing these settings the status monitor hasn't yetgone back to offline. I'd struggled for days before I got it sorted; the onlinehelp hadn't been much help. I hope this helps.
Jan 19, 2011 | Brother HL-2040 Laser Printer
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
My HP Officejet J4540 All-in-one printer is showing Offline. I have checked all connections and all appears ok. Could you tell me how to change that status to Ready?
It shows offline if the printer is not communicating. Initially open printers folder and right click the printer icon and check if "use offline" option is not ticked.if its ticked then un-tick it. if everything looks fine then:
1)first try unplugging printer from main power cord for a minute and then plug back in and check after refreshing if it becomes ready.
2)other thing to do is to remove the usb cable from behind the printer and plug back in after 45 seconds.
3)it is also quite possible that the usb port or cable might have gone faulty.in that case try replacing usb cable and check.
thanks ,keep updated and accept the solution.
Sep 02, 2009 | Office Equipment & Supplies
I changed wireless networks and the printer has gone offline. How do I get it back in ready mode? samsung color laser clx-3175
if you changed the wireless router you will need to make sure the settings are the same as you had them before you changed or reinstall it
Jul 21, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
My printer has recently gone offline. I have
Try and shut down the printer and turning it back on. Hold down the power key for 5 seconds or so. Then turn it back on to see if you have your connection showing on your task bar on the bottom of the screen. there should be a green halo around the printer. You may need to reboot your router too.
Jul 13, 2009 | Brother MFC 490cw Color Inkjet...
Star Micronics TSP650 TSP654 POS Network Thermal Receipt Printer Logo
20 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
