Question about Clarisonic Health & Beauty
Clarisonic pro will not change speeds. The red light do not come on.
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Can I send my clarisonic pro to the manufacturers to be repaired?
https://www.youtube.com/watch?v=pvhibytfjNo
Nov 20, 2015 | Optics
ASI Image Pro 2 Treadmill will not start
PLEASE see the video and proceed according. God bless you
Dec 10, 2013 | Exercise & Fitness
Reset ESI 2833 until red light turned green. Network Printer still not responding
Check the IP Address of the 2833. I believe there is a gray button you can depress to print out a configuration sheet. If the wireless modem was also your router, you may have a different IP address range and will need to set the 2833 accordingly.
Sep 03, 2013 | Extended Systems Pocket Print Server
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
My clarisonic mia fell and does noit work anymore
hi there, this happened to mine too. have you fixed yours yet? i have no idea what to do. pls help :(
May 13, 2012 | Clarisonic Mia Sonic Skin Care System
What is the blinking red light on the top of the vacuum
red light blinks when filter needs to b change hope this help thanks for reading
Jan 06, 2012 | Euro-Pro NV31 Infinity Vacuum
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Alarm for speed cameras or red light camers on my tom tom one
1 Change Preference
2 Warn When Near POI
3 Choose Your Red Light Camera POI
4. Set how many yards from it you want to be warned.
5.Choose Sound
Done
Good Luck
Dec 04, 2008 | Tomtom ONE 3rd Edition GPS
Red light is on.
you have to change imaging unit
Sep 10, 2008 | Minolta EP1083 CS/PRO Copier
Health & Beauty Logo
263 people viewed this question
Top Clarisonic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Clarisonic Health and Beauty Expert? Answer questions, earn points and help others
