Question about Panasonic WORKiO DP-2330 Copier
How to see the drum life ir 3025 - Panasonic WORKiO DP-2330 Copier
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
My canon ir 2420 is producing black lines
Generally Black line comes when Drum life is over, check your machine counter, one drum life is 35000-50000 print.
Feb 25, 2015 | Canon Office Equipment & Supplies
Paper jammed in canon ir 3025
adjustment in the right side on casset just turn the nobe
Jan 22, 2014 | Canon ImageRunner 3025 Black and White...
Scanning using canon image runner 3025N
Hi Swandi,
Have you installed the scanner utility software before?. If yes, you can use the software or uses other application such as photoshop :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon ImageRunner 3025 Black and White...
Press shut down key of main machine and restart and error message is 000805-0000
these means that you have fan trouble, probably fan in the rightsideway door.
You need to dismantle upper section of the door to get to the fans, reconnect them and try again.Also if you can remove one fan and by him go to electronics hardweare store and try to buy new.
Second thing:
remove back cover and reconnect all connectors on main pcbs and try then.
If these doesnt help you can write me on emma.servis@gmail for service manual of ir 3025.
hope that helps!
Sep 07, 2010 | Canon ImageRunner 3025 Black and White...
How can i assign a ip address to canon ir3025 in windows
open printer properties of some printer and select PORT, go on ADD PORT, and create IP port, then assign it to Canon Ir 3025. Be sure that the same IP, Subnet and gateway are on PC and copier. Under cmd run ping comand, eg. ping 192.168.1.100, and if you have replay without 100 % loss it would be OK.
Jun 14, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Canon ir 3025 service error
Pls. tell wich sevice error, eg. E019, E007,...
Jan 28, 2010 | Canon ImageRunner 3025 Black and White...
What do we need to purchase to make our IR 3025 network capable?
You need to buy UFRII printer kit for net. printing, and send kit for Scann to e-mail, scan to folder,...
In Europe we cant order any more kits for this product!
Jan 13, 2010 | Canon ImageRunner 3025 Black and White...
What is the drum life on a Canon IR c5185? I have a blue drum over 410%?
The drum life of an printer indicates that how much life is available for the printer before you need to change the drup in simple like it is like how much oil is there in your car to make it run smooth once the drum drains out you need to change it
You can get refurbished drum from market at a lower rate as of not it is 410% so you need not have to worry
All the best
Regards
Nov 30, 2009 | Audio Players & Recorders
Panasonic WORKiO DP-2330 Copier Logo
14 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
