Question about Garmin StreetPilot c530 GPS Receiver
Garmin c530 When I power up this unit, everything seems to be okay until it starts loading the maps, at that point, it just quits and the screen goes black. Is this likely a software issue that can be fixed by downloading the latest version?
  • 4 more comments
  • Anonymous Dec 14, 2007
    When it is plugged in the screen goes blank
  • cayres Dec 31, 2007
    C550 unit. Power up, loading maps.. , screen goes blank.
  • Anonymous Jan 31, 2008
    I have the same problem after the load maps it goes blank. The manufacture sent me a new one the first time this happened. Said it was a glitch with several of these models.. Now 11 months later..the same problem!
  • Anonymous Jul 16, 2008
    error message : "no detailled maps found that support routing,THE sTREETPILOT CANNOT BE USED WITHOU THEM
  • coover Sep 06, 2008
    It powers up, says that it is loading the Maps, and then goes black!
  • revs1 Oct 21, 2008
    I updated to the current version of the software from the Garmin Updater and now all I get is the screen that says "No detailed maps found that support routing. The Streetpilot cannot be used without them." Any ideas. I need this GPS for a work trip tomorrow.
According to technical support, the "glitch" has been fixed with the latest web updater on the Garmin site. In the meantime, you will need to leave the unit unplugged for upto 48 hours to allow the battery die and the unit to get out of its "hang up". Once the battery is completely dead, plug the GPS into a computer (USB) and it should come back to life. Then do the update.
Hope this helps.
Posted on May 16, 2008
While plugged in, my Garmin c530 will shut down immediately after it says "loading maps". Why is this?
This problem only comes up when the battery is not properly charged, therefore not being able to power up the gps beyond the loading map page. Try to reset the unit by holding the power button for about 15 seconds, it will restart the unit, once it restarts it, check if it will get pass the loading map page. Then you try to back up the software on a computer, format it and restore the software back on the unit. If that does not help, then you carry out the following tests.
Try to charge the gps device for about 2 hours then try to turn it on. If it does not come on, then it means the battery did not get charged. That can be a problem from either the battery or the charger or the charging port.
First test the battery by fixing it in another gps and charging it for about 2 hours then turn it on. If it powers on the gps, then it means the battery is okay, but if it does not turn it on, then it means the battery is weak and cannot hold a charge and the solution is for you to replace the battery.
Next you test the charger by trying it out on another gps device, if it turns it on, then it means the charger is intact but if it does not turn it on, then the fault is from the charger.
Finally, test the gps itself by trying to charge in by connecting it to the computer using the USB cable, then you turn it on, if it does not come on, then it means there is a problem with the connection port or there is an internal problem or something with the unit.
Hope this advice was useful to you.
Jan 02, 2011 | Garmin StreetPilot c530 GPS Receiver
I have a garmin street pilot c530 after i power it up and agree to the disclaimer the screen reads as follows no deailed maps found that support routing street pilot cannot be used without them the unit...
I just purchased my c530 a couple of days ago and had been loving it. I had added some custom POI's to my sd card using POI loader version 2.4.0 and that had worked fine. Then the other day I tried to load some new custom POI's, but POI loader got hung up and froze. After disconnecting the c530, I restarted it. After it started, a screen came up that said "No detailed maps found that support routing. The Streetpilot cannot be used without them." I contacted garmin, here is the site for contact info since I am unsure where you are. http://www.garmin.com/garmin/cms/site/us/support/supportcontactand the tech support at Garmin. They said that somehow the files on my c530 must have gotten corrupted. The person I talked to at Garmin was very friendly and walked me through several things trying to get my unit to work. He was very apologetic and said that this should not have happened. He told me I would have to return it and get a replacement. Sorry Hope this helped.
Jun 09, 2008 | Garmin GPS
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
When plugged into power screen displays the garmin logo and a computer with the garmin 530 connected to usb. it seems to charge and works when unpluged until battery runs out. i then have to plug it back...
whne you plug it in through the usb cable the unit is charging but is waiting for you to do something to the software of load something like mp3s. Why are you not using the 12V cable in your vehicle to keep the battery charged.
Oct 30, 2009 | Garmin StreetPilot c530 GPS Receiver
Free garmin c530 map updates
I don't think there is one.  I had to buy an $80.00 CD-ROM for mine.
I did find an article about this here: http://www.gpsmagazine.com/2007/08/garmin_map_update_not_so_smoot.php
Sep 05, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin Nuvi 250W stuck on "Loading Maps..." screen. I know it wasn't a clever thing to do, but I dragged a file (a map i think) into the Nuvi's internal memory via Windows Explorer. Now every PC i have...
Try the reset, and if that fails, download the web updater from the garmin site and try that route.
Master reset will erase all way points or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
Bill 39c203c.gif Learn from your failures or you will fail to learn.  Theory: you understand why it should work but it doesn't
Practice: it works but you have no idea how
   ALL That is necessary for the Triumph Of evil is That good men do nothing.
Aug 30, 2009 | Garmin nuvi 250W GPS Receiver
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
Deleted memory for garmin c530
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. This would allow your to install new maps. You did not delete your internal memory, you deleted your internal maps. Moving the maps from internal to external memory cannot be done on your PC and have them work. They have to be installed on the SD card via Garmin Express. https://support.garmin.com/faqSearch/en-US/faq/content/b17m7lCO3R4UKUAt8x67J7
Mar 21, 2017 | Garmin StreetPilot c530 GPS Receiver
We would like map updates for our c530 garmin
Map updates are available for purchase either from www.garmin.com, or from a local retailer that carries Garmin GPS products.44802
Apr 30, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin C530
There is a Master Reset procedure, but you would lose all of your favorites if you did it. To do a Master Reset, turn the unit off. Press and hold the on button and the bottom right of the screen at the same time. Release the on button when the unit comes on and asks if you want to do a Master Reset. Again, this will ERASE ALL OF YOUR FAVORITES.
Mar 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
283 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
