Question about Samsung DV218AG Gas Dryer
Samsung dryer not getting hot
Samsung dryer. It starts, but it doesn't get hot?
Samsung Dryer Diagnostic Repair & Diagnostic - Not ...
? 19:33
https://www.youtube.com/watch?v=a-8UFyRXBDg
Feb 7, 2014 - Uploaded by ApplianceVideo.com
Troubleshoot your own Samsung Electric Dryer that has some of the ... It powers on but when I get start nothing happens... drum spins but not ...
How To Fix A Clothes Dryer That Is Not Heating Or Drying ...
removeandreplace.com/2013/.../fix-clothes-dryer-heating-drying-clothin...
Sep 21, 2013 - At times your dryer can overheat and this can cause the motor that turns the ... Clothes Dryer Will Not Stay On After Pushing Start Button My dryer will run if I ... I have tried the trouble shooting tips for a dryer that doesn't dry but to no avail. ..... I have a 3 year old electric Samsung dryer and it stopped heating.
[FIXED] Samsung dryer runs, no lint clogs, good airflow, but no ...
forum.partsdr.com > Forum > Appliance Repair Help > Dryer Repair
Mar 12, 2013 - 16 posts - ‎4 authors
I want to check the third harness it but it doesn't look to slide out too easy once I remove the one phillips screw. ... Dryer gets nice and hot now!
Jan 19, 2016 | Samsung Dryers
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Apr 21, 2015 | Samsung Dryers
It is not getting hot
Need heater right hand side in bottom open front panel
Feb 24, 2015 | Samsung 7.3 Cu. Ft. Electric Dryer
Samsung dryer over dries
Sounds like the thermostat sensing tube did not get placed back in it's original position.
Oct 01, 2014 | Samsung DV448AEW 7.4 Cu. Ft. Electric...
Dryer isnt getting hot
It appears that one or more safety limits have failed. You will need an OHM meter to determine which one has failed.
Jan 21, 2013 | Samsung DV220AEW Dryer
Samsung DV338aew does not get hot
I just took the front panel off of my Samsung dryer the belt is off. If you take the front panel off you won't believe what you will see it's so much dust... from all the clothes drying. Did you tried to take the front panel off? First turn off the switch to the dryer at the fuse box so there will be no power in there while you vacuum it out. As soon as I can put the belt on I will vacuum it thoroughly. I'm sure that is the reason why it the temp... is not hot enough.
Good luck.
Erika
Aug 12, 2012 | Samsung DV218AEW Electric Dryer
Stackable dyer gets too hot in the back and i cannot find a filter
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 05, 2011 | Samsung DV316LGW Dryer
SAMSUNG GAS DRYER DV 328 RUNS FOR A WHILE AND THEN STOPS . I GET ERROR CODE EO. THE CLOTHES IN THE DRYER ARE VERY HOT. AFTER A PERIOD OF TIME THE DRYER COOLS DOWN AND STARTS TO WORK AGAIN. THE DRYER...
heatman101
Aug 14, 2011 | Dryers
Dryer is too hot when using lower temp cycles.
heatman101
Jun 28, 2011 | Samsung DV218AEW Electric Dryer
Samsung DV218AG Gas Dryer Logo
18 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
