Question about Sansui HDLCD-2600 26 in. LCD Television
Need remote code for pummel drive
Need remote code
IWDVD-100 Pummel Drive won't change function from dvd to radio. Power goes off when I try to change function
I don't think this is a laptop. Please ask your question in the correct place. Thank you.
Apr 29, 2016 | Computers & Internet
Need code for oneforall tv remote
Most time they have a paper that comes with the remote and a list of TVs look for you make and one at a time punch in the code and then point toward tv and click the on and off button when you enter the right code the tv will either come on or go off.
Aug 29, 2012 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
Need remote code for dvd player
What is the make and model of your remote?
Aug 19, 2012 | Samsung Blue- Ray Disc Player With Bonus...
Clogged print head
Put the black ink cartrige nozzle in warm water and wait several minutes.I don't know if this will work in your case but you should try it. I had similar situation and this helped.
Dec 15, 2011 | Epson Stylus Pro 4800 InkJet Printer
I was driving and the brake light , abs and airbag light came on. the car was still running , however i think i lost some power , the passenager window would not go up and now I am not able to start , what...
Hi, Same problem - with my Hyundai Getz. Thought I'd pummelled the horn too much. However, I'm told that it might be the alternator. Battery completely died and couldn't be charged - AA man cleaned around the alternator ready for new battery, which seemed to work - advised to get new alternator. Didn't! Battery died again few weeks later, but still some power so that I can jump start the car - all lights on! ABS, airbag, brake - you name it! Also, car is brakig itself when driving - this only occurs when all lights are on. Lights eventually go off, and car resumes back to normal driving again - no more bunny hoping a it brakes, and no more smell of rubber. Have read that low power can be a problem for airbag light, and so checking battery, and alternator is a must. My alternator is now being ordered. Hope this helps. If it was anything else let me know.
Jun 11, 2009 | 2001 BMW 5 Series
Code for a Gateway ADC-320 needed
Hi chris_vau888
You could try these codes :- 1100, 1104, 1185, 1221. If none of those work you could try the philips code lookup finder at :- http://www.urc.philips.com/ You will need the remote model number, either from the front of the remote or in the battery compartment.
Hope this helps,
Mark.
Mar 29, 2009 | Gateway ADC-320 DVD Player
Unlocking the region code
There is no known region hack for this player.
Jan 11, 2009 | Sony RDR-VX525 DVD Recorder/VCR
1999 Honda Odyssey A/C
I removed the harness connector and clean both sides with contact cleaner, leave some minutes to dry and connected again. after that it works fine again..
Thanks
Aug 22, 2008 | 1999 Honda Odyssey
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
Sansui HDLCD-2600 26 in. LCD Television Logo
56 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
