Question about Sharp 2.1 Soundbar
Uverse remote codes - Sharp 2.1 Soundbar
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
My Tv is Craig model CLC503. My AT&T Uverse remote will not power on or off the TV.
Access the help section of the menu on your uverse connected TV. Select the option "Remote Control Setup". Select your style of remote and select the type of device that you want to program your remote to and then just simply follow the instructions provided on-screen.
Mar 17, 2014 | AT&T UVerse
I need the AT&T UVerse remote code for my samsung blue-ray player BD-D5700
Feb 01, 2014 | AT&T UVerse
I can find codes for a black standard uverse remote which is 1040. But I cant find a code for silver standard uverse remote. Uverse says to talk to DYNEX. Can you help?
i currently use uverse and none of there remotes work for dynex tv's i suggest buying the logitec harmony 520 or 420 or above remote from amazon read the reviews there around 40 dollars and lets you control everything and they connect to you pc you just plug in you model number and the remote learns all the commands as well as lets you set up activities that will allow you to control multiple devices without having to switch between hitting the tv button, home theater button, uverse box etc.
hope this helps.
Mar 14, 2011 | Televison & Video
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
May 13, 2010 | Zenith ZEN700 Remote Control
I am trying to program my vizio remote to work with my uverse box. would you know the code? other ways around it??
Vizio Television 1343, 1018, 1004, 0178, 0502, 0627, 1756, 1758, 0128, 0117, 1017, 1078, 0030, 0056 VIZIO HDTV 1004
If your tv is HD mute wont work.
This is for programming the uverse remote to the vizo tv. From my understanding the uverse box doesn't have a code.
Dec 01, 2009 | Vizio Televison & Video
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
My att remote control for my uverse did not come with a manuel
Here is the manual for the remote and the codes are there also.
http://helpme.att.net/pdf/uverse/remote_control_user_guide.pdf
Good luck and Please rate FixYa!
Dec 28, 2008 | Televison & Video
Sharp 2.1 Soundbar Logo
26 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
