Question about Summer Infant 12145 Sure And Secure Double Bed rail
Cannot fold down bedrail - Summer Infant 12145 Sure And Secure Double Bed rail
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
How do I remove the mesh to wash it?
From what I've seen, you can't but I'm not familiar with this brand. Usually it's best to sponge clean with water and soap and let dry.
Jan 29, 2016 | The First Years First Years Fold-down...
BedrAILS FOR CHATHAM CONVERTIBLE CRIB
If you are looking to buy bedrails for your Chatham crib, you can try Amazon
http://www.amazon.com/Bassettbaby-Premier-Chatham-Wooden-Bedrails/dp/B004NRP8EE
Jun 12, 2012 | Baby Gear
Need to find the bedrails for a Bassett CRib 5925-0521
Call 1.800.308.7485 Bassett. It is a Bassett Furniture dealer in Virginia. They are very helpful. I was told to use standard full size rails with hooks on each end and that would fit. :)
May 26, 2012 | Bassett Baby Gear
2003 Toyota Corolla LE back seat fold down? how?!
Open the back trunk, look near the top of the trunk, and pull the two black levers. They have a seat folding down symbol. That will release the locks to fold the back seat down.
Jul 03, 2009 | 2003 Toyota Corolla
Need to order bedrails for my Simplicity crib. Style: Prescott. Model: 8854PRW. 1-800-# with instructions is not valid.
I found an 800 number on simplictyforchildren.com website. 1-800-858-8323 this is thier customer service line. hope it helps!
Mar 30, 2009 | Simplicity for Children Prescott 4-in-1...
Bedrail caps
sounds like the dealer, not the product. i would take it to another honda dealer to have them look at it. they will probably tell you that it was installed wrong and i would get my money back from the dealer who did it in the first place. you can fight this. ive seen it many times working in the service department.
Jul 16, 2008 | 2008 Honda Ridgeline
CONVERTING TO TODDLER BED
i found this on the simplicity website, hope it helps. i got mine done i minutes!!!!
Remove Drop side.
Lower drop side. Push in on the tabs at the
bottom of both lower tracks to slide the drop
side down off the tracks as shown.
Position Mattress Support.
Mattress support must be in the lowest
position. If not, use the allen wrench to
remove bolts. Lower support into position
and re-attach to headboard.
Remove upper and lower tracks.
Aug 29, 2007 | Simplicity for Children Ellis 4 in 1 Sleep...
Summer Infant 12145 Sure And Secure Double Bed rail Logo
14 people viewed this question
Top Summer Infant Baby Care Experts
masud
masud
Tom Chichester
Are you a Summer Infant Baby Care Expert? Answer questions, earn points and help others
