Question about Ovens
Emilia oven door does not close properly
Does anyone know how to adjust hinges so that the oven seals properly
  • 1462 Answers
SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Posted on Mar 20, 2007
  • 3 Answers
SOURCE: AMANA CONVECTION OVEN
Kelly~
On the inside of the door, there are screws on both sides a few inches above where the hinges are. These screws if loosened, will remove the entire door. Maybe the screws are just loose or need some adjustment. CAUTION! Make sure you have help because if you break the glass on the outside of the door, you will not be able to replace it because this model has been discontinued.
I have the manual for this oven so if you need further help, just respond to this and hopefully I will get an email.
Good Luck, Linda
LindaAnne
Posted on Jan 01, 2008
  • 146 Answers
SOURCE: kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Posted on Jan 15, 2008
barkencoa
  • 3463 Answers
SOURCE: neff b1421
Replacing the door hinges is the only solution to this problem.
Posted on Dec 07, 2008
barkencoa
  • 3463 Answers
SOURCE: oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Posted on Apr 13, 2010
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 01, 2011 | Neff B1421 Electric Single Oven
Oven door does not close properly it is a pull down door the seal and hinges both look ok can you adjust the hinges
yeah sure
1.cool the oven
2. clean the oven door interior side (remove waste or burnt particles)
3.remove the black caps from the side of oven door
4.loose it upto 2 turns
5. tap the door in the center gently and hold it with one end
6. retighten it
7.And you are done.
thanks
rate me for my work
Aug 28, 2011 | Ovens
The oven door (Model SMW272) does not close completely. It may need an adjustment or a new seal?
Generally speaking, if a oven door does not close properly, and it is a drop down door, then it usually due to weak springs in the hinges.
There is no adjustment provided, so the only solutiom is to replace both door hinges.
Please rate my nsolution.
Thankyou.
Jan 28, 2010 | Thermador SMW272 Electric Double Oven
Oven door fails to close properly. Heat escapes when cooking. Seals appear to be ok. Please assist if free, as offered.
Probably mal-adjusted hinges. Open the door fully and there USUALLY are small holes in the hinges to insert a nail into to hold the hinges open while working on the door.
Nov 25, 2009 | Fisher Ovens
Oven door does not fully close
The usual reason for oven doors not closing properly, is weak door hinges,if it does not close all the way, and the door seal is o/k, then I suggest you replace both door hinges. Please rate my solution. Thamks.
Jun 06, 2009 | Amana AOCS3040 Electric Single Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Oven door not closing correctly
I had the same type of problem. I unhinged the door then disassembled the door (it's really quite easy)
after you take all the TORX screws out the everything comes apart! Don't worry about the screws putting them back is a snap! Now that you have the door apart take the door hinges out of the inner door plate.
If you look at then closely they will have a slight bend in them. Pay attention to how they would have been positioned on the door! Simply bend them slightly I used the edge of a step! My door now shuts completely! I hope this info helps many of you having the same problem! If you take the time it really is amazing how easy it is to solve the door issue! Thanks to my buddy RON.
Aug 06, 2008 | Bosch HBL 435 Stainless Steel Electric...
Kenmore oven model# 790.79383401 door not closing
Jan 15, 2008 | Ovens
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Ovens Logo
67 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
