Question about GE JVM1650 1000 Watts Microwave Oven
Please help need microve to warm up babys food
My girlfriend put a bowl in the microwave and it had a metal rim on it needless to say it put a small hole on the inside plastic and the outside plastic on the door of the microwave the metal grill thing is fine but I was wonderingif there is a safe, easy and cheap way to fix it because we just had a baby and are strpped for cash at the moment the model of microwave is GE JES78WJ02 th kw is: 0.95 and VAC/HZ is : 120/ 60. and I dont have an ohmmetter to test the connectivity
  • benjisdaddy1 Jun 20, 2009
    the model number was wrong it is ge jes738wj 02
2 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: Hole in plastic on inside of door
check the conductivity of the plastic with an ohmmeter by placing the probes an inch apart on the plastic surface. If the resistance is large or infinity, the plastic probably performs no role in stopping the microwave radiation. If so, any epoxy probably can be used to close the hole safely. Make sure you don't use too much and if possible place tape over the repair and orient the microwave so the epoxy presses against the tape while drying to prevent it from oozing into any door hinge/close mechanism. Otherwise, a piece of microwave door glass from a broken unit can ge glued over the hole and should stop the radiation. You can check for leakage with test units but be very carefuly anyway.
Posted on Nov 30, 2007
My microwave model mv1526w when I press start it start to spark...What makes it spark and can I fix it?
It might be the appliance isn't properly grounded or it might be it is faulty or it might be there is something inside that is unsuitable.
Microwave ovens should not be operated with nothing inside and only suitable containers should be used to hold food for heating. Cups or plates with gold painted rims and metal containers and those containing metal are likely to cause a veritable electrical storm inside.
Mar 06, 2017 | Microwave Ovens
Why do microwaves have little holes on the inside top, left and right? I loosen the panel near the control switches, and I can see through them to inside the microwave, while it is on. Concern?
the holes are to allow condensation and heat to escape during the cooking process
you will notice that the glass door is made up of many small holes so that you can see the cooking process
the holes are of such a size that the length of the microwave is unable to penetrate and so cause radiation outside the oven
tat is what the oven light is outside the oven proper ( behind the holes section) as the micro waves cannot get to the metal fixture
If you are still concerned , talk with a repair shop
Jan 02, 2016 | Kenmore Microwave Ovens
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Sharp r520kst door won't stay shut
Aug 20, 2012 | Sharp Microwave Ovens
While cooking in our Whirlpool GH5184 microwave an arcing appeared near the L/H lower corner of the unit. After shutting it off we observed a black arc mark on the inside of the door and a small hole from...
This is caused by either carbon arcing from carbonated food deposits or metal dish or bowl being used inside the machine causing a track. Even a recycled paper towel can cause it as the towels have metal traces in them.
Dec 13, 2010 | Whirlpool GH5184XPQ Microwave Oven
We put a plastic jar with a very small piece of foil on the rim and the microwave started to smoke. it might have run 30 seconds before we noticed it making a funny noise. it is a 1200 watt inverter
Hello Dwight,
You may have damaged the microwave. Since the oven cavity is a tuned cavity, introducing metal into it can wreck havoc on the magnetron (microwave generator itself).
Did you happen to notice if the smoke was from the plastic jar (plastic heating up from the high temp of the foil ring), or if it was the actual microwave smoking (and not blowing smoke out of the oven cavity from the plastic jar)?
Sep 14, 2010 | Panasonic MCM INVERTER
Can you run a microwave with nothing in it? Someone told me that just putting a sponge in it will ruin the microwave.
hi, running it with nothing in it will cause it no harm, the only object that will cause it any harm is if you place anything metalic inside it whilst it is switched on.
to clean a microwave most people place a bowl of clean water inside and put the microwave on high for 5 to 10 min doing this breaks up any grime stuck inside the microwave making it easier to wipe off, you can also put a wet cloth in a bowl and switch it on doing this does the same as a bowl of water.
so the only thing that can cause damage is anything with metal in it this will cause it to short out.
hope that has been some help to you
Aug 18, 2010 | Sharp R-1480 Microwave Oven
My sharp r-510hw flashing like crazy
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 22, 2008 | Sharp R-510HW Microwave Oven
Nov 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
