Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Electric lights won't go on? - Intermatic & Indoor/Outdoor Rain Tight Timer
2 Hot Plates won`t work
If it's a gas buner usually the pilot light tube is clogged. If it's electric either the switch or the electric element isdefective. Did they both go out at the same time?
Mar 12, 2015 | Cooktops
Nobs on stove won't go off
For starters turn the electric off. Is your range gas or electric? When you turn the knobs to off do the lights stay on? What brand and model number do you have?
Jul 30, 2013 | Cooktops
Electric furnace won't light
tony this is a gas furnance do you seee a orange glow on the right hand side of unit
Jan 22, 2013 | Heating & Cooling
The lights won't work properly
sounds like contacst in light switch are bad. replace light switch
Nov 26, 2012 | Yamaha Pz480 Phazer Pz 480 Electric Start...
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Jun 05, 2012 | Bosch Nexxt WTMC 6300 Electric Dryer
If I plug in my trailer and turn on the ref.model 2652 it works fine. I can convert it over to gas with no problem when it has been running off electric but if I try to light it on gas first it won't...
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Your problem seems to be in the control circuitry but I don't think it is a true fault. I would suspect corrosion on the connectors of the upper and lower control boards instead of a faulty control board.
I use a combination of scouring pad and #2 pencil eraser to clean the contacts.
Sep 06, 2011 | Dometic RM2652 Refrigerator
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
Lock won`t open
Look for a button or sensor which turns the light off or which the door would press when closed.
If you find it hold it down for a minute, then let go this should reset the lock
Aug 13, 2008 | Frigidaire FEF352 Electric Kitchen Range
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
51 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
