Question about Campbell Hausfeld 2500 Psi, 2.4 Gpm, Gcv160 Honda Powered Pressure Washer
Pressure washer is kicking back when I start it
I have a honda gx 390 that kicks back when i pull the rope to start
The ignition timing may be too advanced . Some times if the pull start rope is not pulled hard enough it will kick back, The ignition fires just before top dead center , if not pulled hard enough it will kick back.
Oct 15, 2014 | Garden
Motor turns over but seems to be a lot of pressure on it . it kicks back hard
Make sure you are holding the trigger and water is spraying while you are trying to start it, otherwise pressure will build up in the pump and it will kick back.
Jun 06, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Engine does not start easily after shut off
if there is water pressure still hooked up then pump is primed and a sensor { that kicks the idle down when not pulling the trigger} is restricting the fuel flow. see if problem continues without pressure
May 03, 2010 | Dewalt DPD3300 Commercial Pressure Washer
I have a M157305J North Star pressure washer. The
The thermostat in the control is sticking... by turning it a bit you get it to release and kick back on...
You need to replace the control...
Heatman101
Mar 03, 2010 | Garden
Preasure washer want preasure up. engine runs find but wand want kick into high preasure
Start the engine on your pressure cleaner then with your lance change it to low pressure as if you were applying detergent i think your model has the 5 different quickfit jets put the large derergent one in and give it a hit...
Then put the high pressure jet back in and see if it will build up pressure now, if this works then your bypass/unloader valve is sticking in the head it will need removing and cleaning up and lubricating...
This is the most common cause of not building up pressure and is usually caused by sitting around and not using the pressure cleaner regulary...
Good Luck!!! Hope this helps
Kind Regards
Brad
Jan 03, 2010 | Karcher 2500 PSI Pressure Washer
Lack of pressure after releasing the trigger on the wand
Hello awcockerill:
This sounds like the bypass (unloader) valve is sticking. Here is a diagram of your machine's pump. On page 2.4 see part #1. The top of this assembly is a black plastic cover. Remove all of assembly # 1 carefully. Under that is part #8. This is the bypass valve. You need to pull this out, check that the o-rings are not bent, worn or damaged, then lube it good with a VERY VERY good waterproof grease. Re-assemble it and all should be well. The part numbers are on the diagram but where to get them depends on were you live. Karcher web site may give you a number to call. Good luck.
Aug 24, 2009 | Karcher 2500 PSI Pressure Washer
PRESSURE WASHER DOESNT HAVE MUCH PRESSURE, MOTOR DOESNT EVEN KICK DOWN LIKE ITS UNDER LOAD
Make sure that the tip of the head is not damaged, or missing anything.
Sometimes, there can be a pressure leak from the tip of the lance, inhibiting the pump from kicking in properly.
Hope that helps.
Jul 28, 2009 | Honda Pressure Washer PSI 3000
Can't start the Honda GX160 5.5 HP Electric motor on my Chore Master 2400psi Pressure Washer. Got gas (checked through feed line), new spark plug, switch on, gas, choke ok, throttle a bit funky (about 12...
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Apr 27, 2009 | Garden
Campbell Hausfeld 2500 Psi, 2.4 Gpm, Gcv160 Honda Powered Pressure Washer Logo
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
