Question about Precor Exercise & Fitness
Efx 521i My 521i says Error, how can I restart my ellipiticaly
How do I replace the battery on efx 546i
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
MY EFX SAYS ERROR 30 WHAT WRONG WITH IT
Errors 30 through 33 all indicate the loss of communications or erratic communications betweenthe microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures forall of the are essentially the same. Error 30 is defined as upper PCA not receiving from lowerPCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lowerPCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCAPossible Causes1. An upper PCA to lower PCA interconnect cable is bad.2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.3. A 5.17 EFX equipped with version 1.01 upper and lower software.4. A 5.17 with mismatched upper and lower software.5. A defective lower PCA.6. A defective upper PCA.Possible Remedies1. Substitute a know good interconnect cable between the upper and lower PCAs to determineif the interconnect cable is defective.2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upperPCA connector.3. Replace the 5.17 upper and lower software with the most current software versions.4. If only one of the upper or lower software is version 1.01, replace the version 1.01 softwarewith the most current version of software.5. Substitute a known good lower PCA to determine if the lower PCA is defective.6. Substitute a known good upper PCA determine if the upper PCAs defective.
Mar 23, 2013 | Precor Efx-5.33 Elliptical Machine...
"stuck key" message on efx 546i, will not engage, already replaced batttery
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
What is error 45 on the EFX 546??
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Nov 11, 2012 | Precor EFX 546i Elliptical Version 4
Whenever I use our eliptical precor efx, as soon as the elevation starts it says error 45
Aug 10, 2010 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
32 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
