Question about HTC Cell Phones
Disassemble htc6990l phone - HTC Cell Phones
I want to see pcb identification
Follow these links
http://www.celtnet.org.uk/mobile-phone/manufacturer.php?id=11
http://www.celtnet.org.uk/mobile-phone/disassembly-instructions.php?pid=167
http://www.celtnet.org.uk/mobile-phone/disassembly-instructions.php?pid=163
http://www.celtnet.org.uk/mobile-phone/disassembly-instructions.php?pid=164
This link you help more ,
http://gsmsolutionforum.blogspot.com/2010/12/nokia-6300-memory-card-problem-solution.html
Hope this helps
Jan 22, 2011 | Nokia 3310 Cellular Phone
My iphone 4 does not ring!
Hi,What causes phones not to ring out is when the ringer that makes you hear a tone when someone calls is damaged and does not work properly again.
The ringer is located inside the phone.You can get access into the phone by disassembling the phone with a phone screw. It a little bit technical when unscrewing the phone.Just be careful not to damage the phone.
How to disassemble the phone.
You can use the below link to disassemble the phone
jorymon.com/tag/unscrewing-iphone-3gs/
Note:if you can't loose the phone, in other not to cause damage to the phone,please contact a skill full personnel for assistance.Thanks.
Thanks for using fixya........
Before you replace it,you can also clean up the ringer ,there might be dirt stopping it from working properly.
Have a nice day.
Jan 10, 2011 | Apple iPhone 3GS Black (16 GB)
Speaker
the speaker is inside the phone you must disassemble it to replace the speaker.. heres the disassembly video for 5310 express music.. http://www.youtube.com/watch?v=h1vUXp_UKB4
Jul 20, 2010 | Nokia 5310 Cellular Phone
Samsung T301G disassembly?
I do not know, but I have the same phone and I'm trying to disassemble it too. I got the back panel off, but I wasn't able to get the panel holding the screen in place off; I think there are some hidden screws. All the screws are small phillips (plus-shaped).
Jan 25, 2010 | Samsung Cell Phones
I dropped my blackjackII and the power buttton on the verytop of the phone is jammed and not working.how do i get it to turn on?
The phone external casing must be disassembled and assembled back, checking keypad connector and refitting the keyboard in place.
If that does not work, then the keypad must be replaced.
Here a video on how to disassemble Blackjack, procedure is the same on BJ II : Samsung Blackjack Disassembly .
It is better having the job done at a phone repair shop, so that you do not risk to cause more damage to your phone.
Jul 08, 2009 | Samsung Blackjack SGH-I607 Smartphone
How to dismantle samsung-e630
Visual aids for this specific model are not available online , but you can get the service manual for about $3 : Samsung E630 Service Manual: ASSEMBLY, DISASSEMBLY, REPAIR -
You can also refer to disassembly instructions for similar Samsung models:
d500 assemble disassemble part1
Samsung SGH-D500 Disassembly-Assembly Video
Mar 16, 2009 | Samsung SGH-E630 Cellular Phone
Samsung U700 disassembly problem
Remove the large white identification label from the rear of the slide and you will find 6 small screws. Once these have been removed you can seperate the the slide and access the flex cable connector. The service manual for the SGH-U600 which shows full disassembly instuctions can be found here.
http://rapidshare.com/files/109427156/SGH-U600_SVC_Manual_070403.pdf
Nov 13, 2008 | Samsung SGH-U700 Cellular Phone
Cu400 disassebly
you should take the phone to a professional mobile service center and have them disassemble the phone for you.
Feb 08, 2008 | LG CU400 Cellular Phone
Cell Phones Logo
108 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
