Question about GE NX488 - Wireless ShatterPro Glassbreak Sensor
Malfunction The sensor is reporting to the main control panel a "malfunction". We replaced the batteries and it still is intermittently giving this error. What does it mean?
    Champion:
  • 216 Answers
Did you clear the low battery condition, using the touch pad ???
Posted on Apr 26, 2014
Trouble code in a 2003 kia Sedona PO106
These are the only ones I have listed
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bankicon1.png 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiencyicon1.png below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performanceicon1.png.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassisicon1.png Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motoricon1.png Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short
Oct 01, 2014 | Vehicle Parts & Accessories
Where is the bank 1 sensor 1 air flow sensor located on a 2000 toyota avalon?
Sensor diagram for a 2000 toyota avalon and list of Pcodes dbd372cc-f8f3-49ef-b0c2-2adab46c4182.jpg 8fc069a5-bedc-447d-a1ef-4335798a0a0f.jpg
P0100 Mass or Volume Air Flow Circuit Malfunction
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit Malfunction
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Malfunction
P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch "A" Circuit Intermittent
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature For Stable Operation
P0130 O2Circuit Malfunction (Bank #1 Sensor #1)
P0131 O2Sensor Circuit Low Voltage (Bank #1 Sensor #1)
P0132 O2Sensor Circuit High Voltage (Bank #1 Sensor #1)
P0133 O2Sensor Circuit Slow Response (Bank #1 Sensor #1)
P0134 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #1)
P0135 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #1)
P0136 O2Sensor Circuit Malfunction (Bank #1 Sensor #2)
P0137 O2Sensor Circuit Low Voltage (Bank #1 Sensor #2)
P0138 O2Sensor Circuit High Voltage (Bank #1 Sensor #2)
P0139 O2Sensor Circuit Slow Response (Bank #1 Sensor #2)
P0140 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #2)
P0141 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #2)
P0142 O2Sensor Circuit Malfunction (Bank #1 Sensor #3)
P0143 O2Sensor Circuit Low Voltage (Bank #1 Sensor #3)
P0144 O2Sensor Circuit High Voltage (Bank #1 Sensor #3)
P0145 O2Sensor Circuit Slow Response (Bank #1 Sensor #3)
P0146 O2Sensor Circuit No Activity Detected (Bank #1 Sensor #3)
P0147 O2Sensor Heater Circuit Malfunction (Bank #1 Sensor #3)
P0150 O2Sensor Circuit Malfunction (Bank #2 Sensor #1)
P0151 O2Sensor Circuit Low Voltage (Bank #2 Sensor #1)
P0152 O2Sensor Circuit High Voltage (Bank #2 Sensor #1)
P0153 O2Sensor Circuit Slow Response (Bank #2 Sensor #1)
P0154 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #1)
P0155 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #1)
P0156 O2Sensor Circuit Malfunction (Bank #2 Sensor #2)
P0157 O2Sensor Circuit Low Voltage (Bank #2 Sensor #2)
P0158 O2Sensor Circuit High Voltage (Bank #2 Sensor #2)
P0159 O2Sensor Circuit Slow Response (Bank #2 Sensor #2)
P0160 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #2)
P0161 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #2)
P0162 O2Sensor Circuit Malfunction (Bank #2 Sensor #3)
P0163 O2Sensor Circuit Low Voltage (Bank #2 Sensor #3)
P0164 O2Sensor Circuit High Voltage (Bank #2 Sensor #3)
P0165 O2Sensor Circuit Slow Response (Bank #2 Sensor #3)
P0166 O2Sensor Circuit No Activity Detected (Bank #2 Sensor #3)
P0167 O2Sensor Heater Circuit Malfunction (Bank #2 Sensor #3)
P0170 Fuel Trim Malfunction (Bank #1)
P0171 System Too Lean (Bank #1)
P0172 System Too Rich (Bank #1)
P0173 Fuel Trim Malfunction (Bank #2)
P0174 System Too Lean (Bank #2)
P0175 System Too Rich (Bank #2)
P0176 Fuel Composition Sensor Circuit Malfunction
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor "A" Circuit Malfunction
P0181 Fuel Temperature Sensor "A" Circuit Range/Performance
P0182 Fuel Temperature Sensor "A" Circuit Low Input
P0183 Fuel Temperature Sensor "A" Circuit High Input
P0184 Fuel Temperature Sensor "A" Circuit Intermittent
P0185 Fuel Temperature Sensor "B" Circuit Malfunction
P0186 Fuel Temperature Sensor "B" Circuit Range/Performance
P0187 Fuel Temperature Sensor "B" Circuit Low Input
P0188 Fuel Temperature Sensor "B" Circuit High Input
P0189 Fuel Temperature Sensor "B" Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit Malfunction
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low Input
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor Malfunction
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P0200 Injector Circuit Malfunction
P0201 Injector Circuit Malfunction - Cylinder #1
P0202 Injector Circuit Malfunction - Cylinder #2
P0203 Injector Circuit Malfunction - Cylinder #3
P0204 Injector Circuit Malfunction - Cylinder #4
P0205 Injector Circuit Malfunction - Cylinder #5
P0206 Injector Circuit Malfunction - Cylinder #6
P0207 Injector Circuit Malfunction - Cylinder #7
P0208 Injector Circuit Malfunction - Cylinder #8
P0209 Injector Circuit Malfunction - Cylinder #9
P0210 Injector Circuit Malfunction - Cylinder #10
P0211 Injector Circuit Malfunction - Cylinder #11
P0212 Injector Circuit Malfunction - Cylinder #12
P0213 Cold Start Injector #1 Malfunction
P0214 Cold Start Injector #2 Malfunction
P0215 Engine Shutoff Solenoid Malfunction
P0216 Injection Timing Control Circuit Malfunction
P0217 Engine Over Temperature Condition
P0218 Transmission Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Malfunction
P0221 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch "B" Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch "C" Circuit Malfunction
P0226 Throttle/Pedal Position Sensor/Switch "C" Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch "C" Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch "C" Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch "C" Circuit Intermittent
P0230 Fuel Pump Primary Circuit Malfunction
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Engine Over Boost Condition
P0261 Cylinder #1 Injector Circuit Low
P0262 Cylinder #1 Injector Circuit High
P0263 Cylinder #1 Contribution/Balance Fault
P0264 Cylinder #2 Injector Circuit Low
P0265 Cylinder #2 Injector Circuit High
P0266 Cylinder #2 Contribution/Balance Fault
P0267 Cylinder #3 Injector Circuit Low
P0268 Cylinder #3 Injector Circuit High
P0269 Cylinder #3 Contribution/Balance Fault
P0270 Cylinder #4 Injector Circuit Low
P0271 Cylinder #4 Injector Circuit High
P0272 Cylinder #4 Contribution/Balance Fault
P0273 Cylinder #5 Injector Circuit Low
P0274 Cylinder #5 Injector Circuit High
P0275 Cylinder #5 Contribution/Balance Fault
P0276 Cylinder #6 Injector Circuit Low
P0277 Cylinder #6 Injector Circuit High
P0278 Cylinder #6 Contribution/Balance Fault
P0279 Cylinder #7 Injector Circuit Low
P0280 Cylinder #7 Injector Circuit High
P0281 Cylinder #7 Contribution/Balance Fault
P0282 Cylinder #8 Injector Circuit Low
P0283 Cylinder #8 Injector Circuit High
P0284 Cylinder #8 Contribution/Balance Fault
P0285 Cylinder #9 Injector Circuit Low
P0286 Cylinder #9 Injector Circuit High
P0287 Cylinder #9 Contribution/Balance Fault
P0288 Cylinder #10 Injector Circuit Low
P0289 Cylinder #10 Injector Circuit High
P0290 Cylinder #10 Contribution/Balance Fault
P0291 Cylinder #11 Injector Circuit Low
P0292 Cylinder #11 Injector Circuit High
P0293 Cylinder #11 Contribution/Balance Fault
P0294 Cylinder #12 Injector Circuit Low
P0295 Cylinder #12 Injector Circuit High
P0296 Cylinder #12 Contribution/Balance Fault
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder #1 - Misfire Detected
P0302 Cylinder #2 - Misfire Detected
P0303 Cylinder #3 - Misfire Detected
P0304 Cylinder #4 - Misfire Detected
P0305 Cylinder #5 - Misfire Detected
P0306 Cylinder #6 - Misfire Detected
P0307 Cylinder #7 - Misfire Detected
P0308 Cylinder #8 - Misfire Detected
P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325 Knock Sensor #1 - Circuit Malfunction (Bank #1 or Single Sensor)
P0326 nock Sensor #1 - Circuit Range/Performance (Bank #1 or Single Sensor)
P0327 Knock Sensor #1 - Circuit Low Input (Bank #1 or Single Sensor)
P0328 Knock Sensor #1 - Circuit High Input (Bank #1 or Single Sensor)
P0329 Knock Sensor #1 - Circuit Input Intermittent (Bank #1 or Single Sensor)
P0330 Knock Sensor #2 - Circuit Malfunction (Bank #2)
P0331 Knock Sensor #2 - Circuit Range/Performance (Bank #2)
P0332 Knock Sensor #2 - Circuit Low Input (Bank #2)
P0333 Knock Sensor #2 - Circuit High Input (Bank #2)
P0334 Knock Sensor #2 - Circuit Input Intermittent (Bank #2)
P0335 Crankshaft Position Sensor "A" Circuit Malfunction
P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
P0337 Crankshaft Position Sensor "A" Circuit Low Input
P0338 Crankshaft Position Sensor "A" Circuit High Input
P0339 Crankshaft Position Sensor "A" Circuit Intermittent
P0340 Camshaft Position Sensor Circuit Malfunction
P0341 Camshaft Position Sensor Circuit Range/Performance
P0342 Camshaft Position Sensor Circuit Low Input
P0343 Camshaft Position Sensor Circuit High Input
P0344 Camshaft Position Sensor Circuit Intermittent
P0350 Ignition Coil Primary/Secondary Circuit Malfunction
P0351 Ignition Coil "A" Primary/Secondary Circuit Malfunction
P0352 Ignition Coil "B" Primary/Secondary Circuit Malfunction
P0353 Ignition Coil "C" Primary/Secondary Circuit Malfunction
P0354 Ignition Coil "D" Primary/Secondary Circuit Malfunction
P0355 Ignition Coil "E" Primary/Secondary Circuit Malfunction
P0356 Ignition Coil "F" Primary/Secondary Circuit Malfunction
P0357 Ignition Coil "G" Primary/Secondary Circuit Malfunction
P0358 Ignition Coil "H" Primary/Secondary Circuit Malfunction
P0359 Ignition Coil "I" Primary/Secondary Circuit Malfunction
P0360 Ignition Coil "J" Primary/Secondary Circuit Malfunction
P0361 Ignition Coil "K" Primary/Secondary Circuit Malfunction
P0362 Ignition Coil "L" Primary/Secondary Circuit Malfunction
P0370 Timing Reference High Resolution Signal "A" Malfunction
P0371 Timing Reference High Resolution Signal "A" Too Many Pulses
P0372 Timing Reference High Resolution Signal "A" Too Few Pulses
P0373 Timing Reference High Resolution Signal "A" Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal "A" No Pulses
P0375 Timing Reference High Resolution Signal "B" Malfunction
P0376 Timing Reference High Resolution Signal "B" Too Many Pulses
P0377 Timing Reference High Resolution Signal "B" Too Few Pulses
P0378 Timing Reference High Resolution Signal "B" Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal "B" No Pulses
P0380 Glow Plug/Heater Circuit "A" Malfunction
P0381 Glow Plug/Heater Indicator Circuit Malfunction
P0382 Glow Plug/Heater Circuit "B" Malfunction
P0385 Crankshaft Position Sensor "B" Circuit Malfunction
P0386 Crankshaft Position Sensor "B" Circuit Range/Performance
P0387 Crankshaft Position Sensor "B" Circuit Low Input
P0388 Crankshaft Position Sensor "B" Circuit High Input
P0389 Crankshaft Position Sensor "B" Circuit Intermittent
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor "A" Circuit Low
P0406 Exhaust Gas Recirculation Sensor "A" Circuit High
P0407 Exhaust Gas Recirculation Sensor "B" Circuit Low
P0408 Exhaust Gas Recirculation Sensor "B" Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve "A" Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve "A" Circuit Open
P0414 Secondary Air Injection System Switching Valve "A" Circuit Shorted
P0415 Secondary Air Injection System Switching Valve "B" Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve "B" Circuit Open
P0417 Secondary Air Injection System Switching Valve "B" Circuit Shorted
P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank #1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank #1)
P0422 Main Catalyst Efficiency Below Threshold (Bank #1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank #1)
P0424 Heated Catalyst Temperature Below Threshold (Bank #1)
P0430 Catalyst System Efficiency Below Threshold (Bank #2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank #2)
P0432 Main Catalyst Efficiency Below Threshold (Bank #2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank #2)
P0434 Heated Catalyst Temperature Below Threshold (Bank #2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (Small Leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction P0441 and/or P0446
Apr 02, 2014 | 2000 Toyota Avalon
Need codes for UBD2 reader
Try these.
P1000OBD-II Monitor Testing Incomplete
P1001KOER Test Cannot Be Completed
P1039Vehicle Speed Signal Missing or Improper
P1051Brake Switch Signal Missing or Improper
P1100Mass Air Flow Sensor Intermittent
P1101Mass Air Flow Sensor out of Self-Test Range
P1112Intake Air Temperature Sensor Intermittent
P1114Intake Air Temperature 2 Circuit Low Input
P1115Intake Air Temperature 2 Circuit High Input
P1116Engine Coolant Temperature Sensor is out of Self-Test Range
P1117Engine Coolant Temperature Sensor Intermittent
P1120Throttle Position Sensor out of range
P1121Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
P1124Throttle Position Sensor out of Self-Test Range
P1125Throttle Position Sensor Intermittent
P1127Heated Oxygen Sensor Heater not on During KOER Test - Exhaust Not Warm Enough
P1129Upstream O2 Sensors Swapped Bank To Bank (HO2S-11-21)
P1130Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
P1131Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1132Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1135Ignition Switch Signal Missing or Improper
P1137Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
P1138Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P1150Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 2
P1151Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1152Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1157Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1158Lack of Downstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 2
P1168FRP Sensor In Range But Low
P1169FRP Sensor In Range But High
P1180Fuel Delivery System Low
P1181Fuel Delivery System High
P1183EOT Sensor Circuit Malfunction
P1184EOT Sensor Out Of Range
P1220Series Throttle Control fault
P1224Throttle Position Sensor B out of Self-Test Range
P1229Supercharger Intercooler Pump Not Working
P1230Open Power to Fuel Pump circuit
P1231High Speed Fuel Pump Relay activated
P1232Low Speed Fuel Pump Primary circuit failure
P1233Fuel Pump Driver Module off-line
P1234Fuel Pump Driver Module off-line
P1235Fuel Pump Control out of range
P1236Fuel Pump Control out of range
P1237Fuel Pump Secondary circuit fault
P1238Fuel Pump Secondary circuit fault
P1244Generator Load Input Low
P1245Generator Load Input High
P1246Generator Load Input Failed
P1250Lack of Power to FPRC Solenoid
P1260Theft Detected - Engine Disabled
P1270Engine RPM or Vehicle Speed Limiter Reached
P1285Cylinder Head Over Temperature Sensed
P1288Cylinder Head Temperature Sensor out of Self-Test Range
P1289Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range
P1290Cylinder Head Temperature Sensor Signal Less Than Self-Test Range
P1299Cylinder Head Temperature Sensor Detected Engine Overheating Condition
P1309Misfire Detection Monitor not enabled
P1336CKP and/or CMP Input Signal to PCM Concerns
P1351Ignition Diagnostic Monitor circuit Input fault
P1352Ignition Coil A - Primary circuit fault
P1353Ignition Coil B - Primary circuit fault
P1354Ignition Coil C - Primary circuit fault
P1355Ignition Coil D - Primary circuit fault
P1356Loss of Ignition Diagnostic Module Input to PCM
P1358Ignition Diagnostic Monitor Signal out of Self-Test Range
P1359Spark Output circuit fault
P1364Ignition Coil Primary circuit fault
P1380Variable Cam Timing Solenoid A Circuit Malfunction
P1381Variable Cam Timing Over-advanced (Bank 1)
P1383Variable Cam Timing Over-retarded (Bank 1)
P1390Octane Adjust out of Self-Test Range
P1400Differential Pressure Feedback Electronic Sensor circuit Low Voltage
P1401Differential Pressure Feedback Electronic Sensor circuit High Voltage
P1403Differential Pressure Feedback Electronic Sensor Hoses Reversed
P1405Differential Pressure Feedback Electronic Sensor circuit Upstream Hose
P1406Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
P1407EGR No Flow Detected
P1408EGR Flow out of Self-Test Range
P1409EGR Vacuum Regulator circuit malfunction
P1410EGR Barometric Pressure Sensor VREF Voltage
P1411Secondary Air is not being diverted
P1413Secondary Air Injection System Monitor circuit Low Voltage
P1414Secondary Air Injection System Monitor circuit High Voltage
P1432THTRC Circuit Failure
P1436A/C Evaporator Temperature Circuit Low Input
P1437A/C Evaporator Temperature Circuit High Input
P1442Secondary Air Injection System Monitor circuit High Voltage
P1443Evaporative Emission Control System - Vacuum System - Purge Control Solenoid or Purge Control Valve fault
P1444Purge Flow Sensor circuit Input Low
P1445Purge Flow Sensor circuit Input High
P1450Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1451EVAP Control System Canister Vent Solenoid Circuit Malfunction
P1452Inability of Evaporative Emission Control System to Bleed Fuel Tank
P1455Substantial Leak or Blockage in Evaporative Emission Control System
P1460Wide Open Throttle Air Conditioning Cutoff circuit malfunction
P1461Air Conditioning Pressure Sensor circuit Low Input
P1462Air Conditioning Pressure Sensor circuit high Input
P1463Air Conditioning Pressure Sensor Insufficient Pressure change
P1464ACCS to PCM High During Self-Test
P1469Low Air Conditioning Cycling Period
P1473Fan Secondary High with Fans Off
P1474Low Fan Control Primary circuit
P1477MFC Primary Circuit Failure
P1479High Fan Control Primary circuit
P1480Fan Secondary Low with Low Fans On
P1481Fan Secondary Low with High Fans On
P1483Power to Cooling Fan Exceeded Normal Draw
P1484Variable Load Control Module Pin 1 Open
P1500Vehicle Speed Sensor (VSS) Intermittent
P1501Programmable Speedometer & Odometer Module/Vehicle Speed Sensor (VSS) Intermittent circuit-failure
P1502Invalid or Missing Vehicle Speed Message or Brake Data
P1504Intake Air Control circuit malfunction
P1505Idle Air Control System at Adaptive Clip
P1506Idle Air Control Over Speed Error
P1507Idle Air Control Under Speed Error
P1512Intake Manifold Runner Control Stuck Closed
P1513Intake Manifold Runner Control Stuck Closed
P1516Intake Manifold Runner Control Input Error
P1517Intake Manifold Runner Control Input Error
P1518Intake Manifold Runner Control fault - Stuck Open
P1519Intake Manifold Runner Control fault - Stuck Closed
P1520Intake Manifold Runner Control circuit fault
P1530Open or Short to A/C Compressor Clutch circuit
P1537Intake Manifold Runner Control Stuck Open
P1538Intake Manifold Runner Control Stuck Open
P1539Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw
P1549Intake Manifold Temperature Valve Vacuum Actuator Connection
P1550Power Steering Pressure Sensor out of Self-Test Range
P1572Brake Pedal Switch Circuit
P1605PCM Keep Alive Memory Test Error
P1625Voltage to Vehicle Load Control Module Fan circuit not detected
P1626Voltage to Vehicle Load Control Module circuit not detected
P1633Keep Alive Power Voltage Too Low
P1635Tire/Axle Out Of Acceptable Range
P1636Inductive Signiture Chip Communication Error
P1639Vehicle ID Block Not Programmed Or Corrupt
P1640DTC\'s Available In Another Module
P1650Power Steering Pressure Switch out of Self-Test Range
P1651Power Steering Pressure Switch Signal Malfunction
P1700Transmission system problems
P1701Reverse Engagement Error
P1702Transmission system problems
P1703Brake On/Off Switch out of Self-Test Range
P1704Transmission system problems
P1705Transmission Range Sensor out of Self-Test Range
P1709Park or Neutral Position Switch out of Self-Test Range
P1710Transmission system problems
P1711Transmission Fluid Temperature Sensor out of Self-Test Range
P1713Transmission system problems
P1714Transmission system problems
P1715Transmission system problems
P1716Transmission system problems
P1717Transmission system problems
P1718Transmission system problems
P1719Transmission system problems
P1720Transmission system problems
P17294x4 Low Switch Error
P1740Transmission system problems
P1741Torque Converter Clutch Control Error
P1742Torque Converter Clutch Solenoid Faulty
P1743Torque Converter Clutch Solenoid Faulty
P1744Torque Converter Clutch System Stuck in Off Position
P1745Transmission system problems
P1746Electronic Pressure Control Solenoid - Open circuit
P1747Electronic Pressure Control Solenoid - Short circuit
P1749Electronic Pressure Control Solenoid Failed Low
P1751Shift Solenoid No. 1 Performance
P1754Coast Clutch Solenoid circuit malfunction
P1756Shift Solenoid No. 2 Performance
P1760Transmission system problems
P1761Shift Solenoid No. 3 Performance
P1762Transmission system problems
P1767Transmission system problems
P1780Transmission Control Switch circuit is out of Self-Test Range
P17814x4 Low Switch is out of Self-Test Range
P1783Transmission Over-Temperature Condition
P1784Transmission system problems
P1785Transmission system problems
P1786Transmission system problems
P1787Transmission system problems
P1788Transmission system problems
P1789Transmission system problems
P1900Transmission system problems
Mar 25, 2013 | Ford Vehicle Parts & Accessories
I went to scan my toyota yaris car and the following codes were give ; temperature ckt low input po117
EOBD II Error Code: P0117
Fault Location:
Engine Coolant Temperature (ECT) Sensor (G62) - Low Input
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
Coolant thermostat.
Wiring short to earth.
Engine coolant temperature (ECT) sensor.
EOBD II Error Code: P0340
Fault Location:
Camshaft Position (CMP) Sensor A (G40), Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
Wiring from/to Camshaft Position Sensor (CMP) faulty.
Camshaft position (CMP) sensor faulty.
Timing misaligned.
Possible Solutions:
Check Wiring from/to Camshaft Position Sensor.
Check Camshaft Position Sensor.
Check Timing.
EOBD II Error Code: P0500
Fault Location:
Vehicle Speed Sensor (VSS) - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Non Emission Fault - No warning light.
Wiring.
Vehicle speed sensor (VSS).
Engine control module (ECM).
Dec 13, 2012 | 2001 Toyota Yaris
Powerstroke 7.3 2000 two fault codes p0603 and p1211 my reader tells me but i have no manual
p1111 System Pass (No DTCs Available)
P0107 BARO Circuit Low Input
P0l08 BARO Circuit High Input
P0112 IAT Sensor Circuit Low Input
P0113 IAT Sensor Circuit High Input
P0122 Accelerator Pedal Sensor Circuit Low Input
P0123 Accelerator Pedal Sensor Circuit High Input
P0197 EOT Sensor Circuit Low Input
P0198 EOT Sensor Circuit High Input
P0220 Throttle Switch B Circuit Malfunction
P0221 Throttle Switch B Circuit Performance
P0230 Fuel Pump Relay Driver Fail
P0231 Fuel Pump Relay Driver Circuit Failure
P0232 Fuel Pump Relay Driver Failed Off
P0236 Turbo Boost Sensor A Circuit Performance
P0237 Turbo Boost Sensor A Circuit Low Input
P0238 Turbo Boost Sensor A Circuit High Input
P0261 Injector Circuit Low - Cylinder 1
P0262 Injector Circuit High - Cylinder 1
P0263 Cylinder 1 Contribution/Balance Fault
P0264 Injector Circuit Low - Cylinder 2
P0265 Injector Circuit High - Cylinder 2
P0266 Cylinder 2 Contribution/Balance Fault
P0267 Injector Circuit Low - Cylinder 3
P0268 Injector Circuit High - Cylinder 3
P0269 Cylinder 3 Contribution/Balance Fault
P0270 Injector Circuit Low - Cylinder 4
P0271 Injector Circuit High - Cylinder 4
P0272 Cylinder 4 Contribution/Balance Fault
P0273 Injector Circuit Low - Cylinder 5
P0274 Injector Circuit High - Cylinder 5
P0275 Cylinder 5 Contribution/Balance Fault
P0276 Injector Circuit Low - Cylinder 6
P0277 Injector Circuit High - Cylinder 6
P0278 Cylinder 6 Contribution/Balance Fault
PO279 Injector Circuit Low - Cylinder 7
P0280 Injector Circuit High - Cylinder 7
P0281 Cylinder 7 Contribution/Balance Fault
P0282 Injector Circuit Low - Cylinder 8
P0283 Injector Circuit High - Cylinder 8
P0284 Cylinder 8 Contribution/Balance Fault
P0301 Fault Cylinder A-Misfire Detected (CYL 1)
P0302 Fault Cylinder B-Misfire Detected (CYL2)
P0303 Fault Cylinder D-Nlisfire Detected (CYL 3)
P0304 Fault Cylinder E-Misfire Detected (CYL 4)
P0305 Fault Cylinder F-Misfire Detected (CYL5)
P0306 Fault Cylinder G-Nlisfire Detected (CYL 6)
P0307 Fault Cylinder C-Misfire Detected (CYL 7)
P0308 Fault Cylinder H-Misfire Detected (CYL 8)
P0340 CMP Sensor Circuit Malfunction
P0341 CMP Sensor Circuit Performance
P0344 CMP Sensor Circuit Intermittent
P0360 Glow Plug Circuit Malfunction
P0381 Glow Plug Indicator Circuit Malfunction
P0460 Fuel Tank Level Indicator Circuit Malfunction
P0470 Exhaust Back Pressure Sensor Circuit Malfunction
P0471 Exhaust Back Pressure Sensor Circuit Performance
P0472 Exhaust Back Pressure Sensor Circuit Low Input
P0473 Exhaust Back Pressure Sensor Circuit High Input
P0476 Exhaust Pressure Control Valve Maffunction
P0476 Exhaust Pressure Control Valve Performance
P0478 Exhaust Pressure Control Valve High Input
P0500 Vehicle Speed Sensor (VSS) Malfunction
P0503 Vehicle Speed Sensor Noisy
PO541 Manifold Intake Air Heater
P0542 Manifold Intake Air Heater
P0560 System Voltage Malfunction
P0662 System Voltage Low
P0666 Cruise 'On" Signal Malfunction
P0566 Cruise "Off' Signal Malfunction
P0667 Cruise 'Resume' Signal Malfunction
P0668 Cruise "Set' Signal Malfunction
P0669 Cruise "Coast' Signal Malfunction
P0571 Brake Svdtch A Circuit Malfunction
P0603 Internal Control Module KAM Error
P0605 Internal Control Module ROM Error
PO606 PCM Processor Fault
P0640 Manifold Intake Air Heater
P0670 Glow plug control circuit malfunction
P0671 Glow plug #1 circuit failure
P0672 Glow plug #2 circuit failure
P0673 Glow plug #3 circuit failure
P0674 Glow plug #4 circuit failure
P0675 Glow plug #5 circuit failure
P0676 Glow plug #6 circuit failure
P0677 Glow plug #7 circuit failure
P0678 Glow plug #8 circuit failure
P0683 Glow plug diagnostic signal communication fault
P0703 Brake Switch B Circuit Malfunction
P0704 Clutch Pedal Position Switch Input Circuit Malfunction
P0705 TR Sensor Circuit Malfunction
P0707 TR Sensor Circuit Low Input
P0708 TR Sensor Circuit High Input
P0712 Transmission Fluid Temp. Sensor CKT Low Input
P0713 Transmission Fluid Temp. Sensor CKT High Input
P0715 TSS Sensor Circuit Malfunction Fault
P0717 TSS Intermittent Failure
P0718 Noisy TSS
P0720 OSS Sensor Circuit Malfunction
P0721 Noisy OSS
P0722 OSS Intermittent Failure
P0732 Gear Two Ratio Error
P0733 Gear Three Ratio Error
P0741 TCC Circuit Performance
P0743 Torque Converter Clutch System Electrical Failure
P0750 Shift Solenoid 1 Malfunction
P0755 Shift Solenoid B Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0800 Logon to http://web.archive.org/web/200701120...utoadvice.com/ A.S.A.P
P1000 OBD 11 Monitor Checks Not Complete. More Driving Required
P1105 Dual Alternator Upper Fault (Monitor)
P1106 Dual Afternator Lower Fault (Control)
P1107 Dual Alternator Lower Circuit Malfunction (Control)
P1108 Dual Alternator BATT Lamp Circuit Malfunction
P1118 Manifold Air Temperature Sensor Low Input
P1119 Manifold Air Temperature Sensor High Input
P1139 Water in Fuel Indicator Circuit Malfunction
P1140 Water in Fuel Condition
P1184 Engine Oil Tamp Sensor Circuit Performance
P1209 Injection Control System Pressure Peak Fault
P1210 Injection Control Pressure Above Expected Level
P1211 ICP Not Controllable - Pressure Abow/Below Desired
P1212 ICP Voltage Not at Expected Level
P1218 CID Stuck High
P1219 CID Stuck Low
P1247 Turbo Boost Pressure Low
P1248 Turbo Boost Pressure Not Detected
P1249 Wastagate Fail Steady State Test
P1250 Electronic Passive Anti-Theft System
P1261 High to Low Side Short - Cylinder 1
P1262 High to Low Side Short - Cylinder 2
P1263 High to Low Side Short - Cylinder 3
P1264 High to Low Side Short - Cylinder 4
P1265 High to Low Side Short - Cylinder 5
P1266 High to Low Side Short - Cylinder 6
P1267 High to Low Side Short - Cylinder 7
P1268 High to Low Side Short - Cylinder 8
P1271 High to Low Side Open - Cylinder 1
P1272 High to Low Side Open - Cylinder 2
P1273 High to Low Side Open - Cylinder 3
P1274 High to Low Side Open - Cylinder 4
P1275 High to Low Side Open - Cylinder 5
P1276 High to Low Side Open - Cylinder 6
P1277 High to Low Side Open - Cylinder 7
P1278 High to Low Side Open - Cylinder 8
P1280 ICP Circuit Out of Range Low
P1281 ICP Circuit Out of Range High
P1282 Excessive ICP
P1263 IPR Circuit Failure
P1284 ICP Failure - Aborts KOER or CCT Test
P1291 High Side No. 1 (Right) Short to GND or B
P1292 High Side No. 2 (Left) Short to GND or B
P1293 High Side Open Bank No. 1 (Right)
P1294 High Side Open Bank No. 2 (Left)
P1295 Multiple Faults on Bank No. 1 (Right)
P1296 Multiple Faults on Bank No. 2 (Left)
P1297 High Sides Shorted Together
P1298 IDM Failure
P1316 Injector Circuit/IDM Codes Detected
P1391 Glow Plug Circuit Low Input Bank No. 1(Right)
P1393 Glow Plug Circuit Low Input Bank No. 2 (Left)
P1395 Glow Plug Monitor Fault Bank No. 1
P1396 Glow Plug Monitor Fault Bank No. 2
P1397 SYstem Voltage Out of Self Test Range
P1464 A/C On During KOER or CCT Test
P1501 VSS Out Of Self Test Range
P1502 Invalid Self Test - APCM Functioning
P1531 Invalid Test -Accelerator Pedal Movement
P1536 Parking Brake Applied Failure
P1662 IDM EN Circuit Failure
P1663 FDCS Circuit Failure
P1667 CID Circuit Failure
P1668 PCM -IDM Diagnostic Communication Error
P1670 EF Feedback Signal Not Detected
P1690 Wastegate Control Valve Malfunction
P1702 TRS Sensor Intermittent Circuit Malfunction
P1704 Digital TRS Failed to Transition State
P1705 TR Sensor out of Self Test Range
P1711 TFT Sensor Out of Self Test Range
P1713 TFT Stuck in Range Low-Below 50'F
P1714 Shilt Solenoid A Inductive Signature Malfunction
P1715 Shift Solenoid B Inductive Signature Malfunction
P1718 TFT Stuck in Range High-Above 25OF
P1728 Transmission Slip Error
P1729 4x4L Switch Error
P1744 Torque Converter Clutch System Performance
P1746 EPC Solenoid Open Circuit
P1747 EPC Solenoid Short Circuit
P1754 CCS (Solenoid) Circuit Malfunction
P1760 EPC Solenoid Short Intermittent
P1780 TCS Circuit Out of self Test Range
P1781 4x4L Circuit Out of Self Test Range
P1783 Transmission Overtemperature Condition
No Code No Communication
No Code Auxiliary Powertrain Control System
No Code Tachometer
Nov 15, 2010 | Ford F-250 Cars & Trucks
What's the error code f 51 is that the main control board
Hello, the reason could be well due to an intermittent connection at the Rotor Position Sensor,(RPS).
To correct this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connection. Confirm that the connector is fully seated onto the RPS control upon final connection and verify there are no damaged wires.Replace the electronic control.The upgraded control is less sensitive to intermittent RPS conection
Thanks
May 30, 2010 | Kenmore Oasis HE 27082 Top Load Washer
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
GE NX488 - Wireless ShatterPro Glassbreak Sensor Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
