Question about Golds Gym R Cycle Trainer 290 C Exercise Bike
6v adapter Where does it plug in to the console
My child was given this keyboard, but it is missing the DC 6V adapter/charger. It looks like we will have to purchase a generic 6V adapter but do I get the 6V 1A or 6V 2A? Thanks in advance!
The keyboard's input should give you the amperage requirement. If not there, get the 2 amp just to make sure it will work. The higher amperage of unit will not harm it if unit calls for 1 amp.
Jun 08, 2016 | Computers & Internet
I need a class 2 power Supply ac/dc adaptor
Shop for I need a class 2 power S... on Google
Phihong ? Wall Mount AC Ada...
$4.68
Mouser Electr... United Security Products AC2P
$15.44
ELVESsupply... Mean Well ? Desktop AC A...
$13.10
Mouser Electr... Ac Adapter For Black & Decke...
$17.99
eBay Generic Ac Adapter Char...
$5.99
eBay Search Results
    Kastar AC DC Adapter Plug-in Class 2 Transformer Power ...
    www.amazon.com > ... > Car Chargers
    Amazon.com, Inc.Kastar AC DC Adapter Plug-in Class 2 Transformer Power Supply Cord Wall .... Provides power to your device in the event you may have lost or damaged your ...
    Amazon.com: Class 2 Power Supply AC Adapter 6V 200mA ...
Dec 14, 2015 | Computers & Internet
PSP NOT WORKING?
If the psp play without the battery when plugged into ac wall unit chances are you need a new battery
http://www.amazon.com/Sony-PSP-Battery-Pack-3-6v-2200mAh/dp/B000FZYY3E
Oct 13, 2013 | Sony PlayStation Portable (PSP) Console
I have koss HD30 2pc. Amplified speakers and I need an AC wall adapter for them. What is the proper adapter for these?
If i remember correct should be between 6V to 9V at 800mA or 1A...if you plug the higher value adapter does not harm your speakers anyway, hope this helps...
Sep 17, 2013 | Video Game Consoles & Games
Hiw many mA does the adapter for labtec lcs150 speakers need
6V DC 200 MA; plus shell, minus center pin
aka, Panasonic AC Adapter Model No. RP-65A or equiv..
You want to make sure the plug at the speaker end is wired properly: + on the outer barrel and minus on the center pin (the adapter will have a little graphic for verification purposes). If so, your 500ma adapter should work fine. The voltage might be a little high but nothing the speakers cannot handle I would think.
Mar 29, 2013 | Labtec LCS 150 Computer Speakers
Where can I get a power adpter for a Northwestern Bell 77340 phone or I know it is a 6V DC adapter, but how many mA?
I'd be surprised if the phone draws a full amp. A 6-volt 1-amp (1000 mA) adapter should be fine. Make sure you get the polarity right on the plug.
Dec 13, 2010 | Cell Phones
I got a Vital Fitness RB260 recumbent bike and it did not come with the AC adapter. I need to know the type, volts and amps or MaMPS or a part number so that I can order one. Thanks.
I have the same bike and my AC adapter is ripped in two. I have also been looking for a replacement cord. The adapter says model:GSD0060450006C
input: 110VAC 60Hz 0.1AMAX
OUTPUT:reg6V 450mA 2.7VA
Please let me know where I can order another one! Thanks!
Nov 21, 2009 | Cycling
Lost Power Adapter for Unicom Mini-switch/8 8 port
method 1: buy a power adapter that has a switch controlled output voltage - they usually have 3V - 4.5V - 6V - 7.5V - 9V and 12V selectable output. Start with 6V and if its not working unplug, select 9 and try again etc. etc.
method 2: open the case and locate an electrolytic capacitor right near the power plug - the biggest one. Note the voltage (for example it may say: 1000uF/15V) and have in mind that your device MUST work at a LOWER level that this.
you can combine the two methods to be safe...
Oct 02, 2009 | Port Incorporated 8-port 100Base-TX Mini...
Looking for a power cord
Hi guys,
Had the same problem yesterday. Went to Radio Shack and picked up a universal power adapter (Model 273-1696). It can be set for 6V and will draw the required 2000mA. Box does not include the right size plug, but the salesman gave me one that fit for no extra charge. Cost 32.99. Everything is working fine now.
Jul 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Golds Gym R Cycle Trainer 290 C Exercise Bike Logo
53 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
