Question about Refrigerators
Frigidaie fpf 200ti
Manual available?
FORD MUSTANG 2013 I HAD BROKEN CAT CONVERTER WITCH I CLEAN IT NOW STILL I HAVE THE CODE P0420 AND P0430 PLEASE HELP
Please read previous answers before reposting the same question.
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0230 - Fuel Pump Primary Circuit Malfunction NOTE: For natural gas applications, the following description applies to the fuel shutoff valve (FSV) circuit.
The PCM monitors the fuel pump (FP) circuit output from the PCM. The test fails if: With the FP output commanded ON (grounded), excessive current draw is detected on the FP circuit; or with the FP output commanded OFF, voltage is not detected on the FP circuit (the PCM expects to detect VPWR voltage coming through the fuel pump relay coil to the FP circuit). Open or shorted fuel pump (FP) circuit
Open VPWR circuit to fuel pump relay
Damaged fuel pump relay
Damaged PCM
When the FPF PID reads YES, a fault is currently present.
An open circuit or short to ground can only be detected with the fuel pump commanded OFF.
A short to power can only be detected with the fuel pump commanded ON.
During KOEO and KOER self-test, the fuel pump output command will be cycled ON and OFF.
Jan 02, 2016 | Ford Cars & Trucks
Beeper will not shut off
Hello David, I appreciate your post!
Based off my understanding your Frigidaire refrigerator will not stop beeping. Is it beeping due to no power or the door being opened for too long? Is it displaying an error code? Where is the noise coming from? Once you have provided me with some additional information I can further assist you. -Matt
Jan 02, 2016 | Frigidaire Ffsc2323le 23 Cu. Ft. Counter...
Frigidaier Side by side Fridge FRS23R4A water leaking from filter casing and no water to water dispensor
Cracked filter head our water line. Best bet is to pull filter head down and inspect water lines and head. Replace if needed
Aug 17, 2012 | Refrigerators
Frigidaier dryer just moved trying to attach dryer vent to back of dryer. only has opening. am i missing a tube that should be there to attach hose to?
Yes their should be a tube that sticks out of the back about 6-8 inches the vent is connected to.The part number for that tube is 131451600 it could be purchased atyour local appliance parts store or it could be ordered online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
to replace that tube the entire dryer must be disassambled to get to the blower housing to connect
Aug 28, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaie affinity washer not puping water. I pulled the pup outy, it seems to be freely spinning. The filter looks like a pipe with an end cap. Does that come out and does it act as a filter. I did find...
the screws and nails were your problem put it back together if it still doesnt pump the pump motor has overloaded from the propeller being obstructed and needs to be replaced.
Jan 11, 2011 | Frigidaire Affinity ATF7000E Front Load...
My refrigirator Frigidaie FRS26H7CSBO started by not making any ice,, then made ice but put to much water that the water came from the ice maker into the door and now the freezer and fresh food side...
I would suggest you unplug it for maybe 15 minutes before restarting. If the condenser is caked with ice maybe a couple of hours would get it defrosted.
Jul 04, 2017 | Frigidaire FRS26H7CS Side by Side...
I have a Frigidai #RG35HW*1 , the oven won't come on, not on bake, broil, preheat, nothing. But everything else works, the burners, the light, the clock/timmer. Just not the oven. Is it something simple...
evene thought he clock timer is functioning it may still be bad and not operate the oven or broiler.this should be replaced they can cost up to 140.00 dollars.also check to make sure that the elements are good if they are good then they clocktimer does need to be replaced
Feb 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Code fpf flashes on clock on ge elec stove model jbp26gs1ad
I am sorry, but there is no such error code mentioned among the GE Fault codes.Or this could possibly be because of a faulty display.The display can be replaced on a call.
Else the possible error code similar to this one is "PF" which refers to power failure but generally not related to kitchen range.
Please do check if there is a display change of the error code and post your valuable comments. would be glad to help.Good luck.
Jan 16, 2009 | GE JSP26 Electric Kitchen Range
Error code: E14 Reed Switch
reeed swith id a small magneteic door switch, i believe frigidaie has taken the m out of newer machine( caused more problem then worth. i would check to see that all doors are closed all the way, especially the dispensor door. theres a slot on the inside of the dispensor assy that holds a small magnet( again theyvce removed from most newer production ) perhaps yours (if indeed oyu had one fell out or became dislodged in moving the unit
Oct 23, 2008 | Frigidaire FWT449
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
