Question about Kenmore Elite 45986 Front Load Washer
Grinding noise and won't spin. Model 796.40441900
Grinding noise. Won't spin. Barrel shaft hot to touch in back
  • 262 Answers
SOURCE: Kenmore washer will not agitate or spin & makes grinding noise
CHECK THE MOTOR coupler located between the motor and then transmission this will be a good place to start if you lean back the washer and look from the bottom you will see a thing between the motor and the tranny that looks like a oreo cookie check and see if that is broken in any way
Posted on Jan 11, 2009
allbrands
  • 600 Answers
SOURCE: Model # 110 20702 991 Serial # CK 5008937 Type 111
Hello, Thank You for using FixYa. I will be helping you today.Sounds like a failed motor coupler part number 285753. It connects the motor to the trans. You can lean the unit back to change this part. Remove the pump remove the motor and you will see it.
Thank You and please rate my answer if it was helpful..
Posted on Jun 10, 2011
SOURCE: my Kenmore 80 series washer won't spin, and it just makes a loud gear grinding noise. What could this be, and how do I fix, in the simplest form please I'm chick... :)
rebecca it is probably the motor coupler. Move or slide ur machine over and if there is ruber filings under it then it is the coupler.
Posted on Apr 12, 2012
dmftrucker
  • 1922 Answers
SOURCE: i have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Posted on Sep 01, 2012
richroth
  • 9472 Answers
SOURCE: Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Posted on Nov 22, 2012
Samsung dryer, model: DV317AEG turns on, but won't spin
Could be the motor is full of lint. Depending on how mechanically inclined you are take the belt off and spin the barrel and the motor separately motor should spin free, barrel a little harder to spin,but spin at least a quarter turn after letting go.
Jul 05, 2012 | Dryers
Whirlpool refrig center section hot
Heat between the doors is normal, It can be a bit concerning but don't worry about it.
The fans do wear out on fridges and can be replaced if the noise bothers you. As long as the fan is still turning it won't affect the operation.
Mar 07, 2012 | Whirlpool Refrigerators
The washer filled up with water but not won't drain spin and is making a funny noise . It's an older magic chef.
The most common issue would be the coupler for the motor transmission. It is a rubber coupling and when it goes bad it makes a grinding, or whirring noise and the machine won't spin or wash. You need to remove the cabinet and look directly under the tub where the motor and tranny connect. This is a reletivly easy and cheap fix. Just google how to replace motor coupling on a top load washer and you may also include your make and model for more direct instructions.
Jun 23, 2011 | Washing Machines
Won' spin out and makes a loud noise like a grinding sound
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Jan 19, 2011 | Washing Machines
Sqeaks and won"t spin
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | Whirlpool LGR5636L Gas Dryer
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
Kenmore Elite 45986 Front Load Washer Logo
42 people viewed this question
fordexpert
Mike Squire
Robert Rankin
