Question about Bosch Power Tools Mini Grinder Spindle 1 EA 114-1375A
Strip down a bosch 1375a mini grinder - Bosch Power Tools Mini Grinder Spindle 1 EA 114-1375A
I need a user manual for bosch model 0601347271 angle grinder
For Bosch Angle Grinder Operating/Safety Instructions 1347A, 1348AE I suggest check this link (under image)...
User Guide link: Bosch Angle Grinder
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice weekend.
Nov 18, 2011 | Saws
I have a Bosch 1375A that I use for many diffrent small work at home. Today I was cutting ceramic with a diamond head wheel. Something I am used to do. After a cut, the grinder didn't want to power-on...
  • Check the fuze in the plug
  • Check the wall socket is working
  • Remove the motor bushings and check them for wear - motor busining should be behind plastic screws located on either side of the motor.
If there is/was a smell of burining out of the motor you may have blown it. This is usually caused by holding the air vents when using it.
Also when you try to turn it on does it make any noise at all? even a quiet buzz sound?
May 09, 2011 | Bosch 1375A 4 - 1/2" Small Angle Grinder -...
We have a Mazzer Super Jolly grinder and we can not get the dosing lever to move without pulling very hard while holding the machine with the other hand. Please help.
your doser mech is possibly gunked up with old grinds, first off try stripping it and cleaning it out, if that doesnt work you may need a new return spring but i think its far more likely to just need a good clean. this is from the mazzer mini but the doser design is pretty much the same so it should help you with disassembly
http://www.home-barista.com/grinders/mazzer-mini-component-photos-t3577.html
May 09, 2011 | Mazzer Coffee-grinder SUPER JOLLY Electric
I have a Bosch 7-1/2"
I could be a bad plug or a frade power cord. Whith the grinder unplugged make sure the grinding wheel turns by hand. If it does it could be a bad on off switch or the brushes in the motor could be worn.
Mar 10, 2011 | Bosch Saws
Worn gears
I would just buy a new one.
parts could cost almost as much.
don't forget the rest of the grinder is just as worn out too
Jun 24, 2010 | Bosch 1375A 412Inch Angle Grinder
How do I open my Bosch MKM 6003 coffee grinder? I can't pry it open and it doesn't have screws!
you should just a little rotate down part of the device. after that it can be taken off.
Dec 17, 2009 | Bosch MKM 6000 Electric Blades Grinder
Manufacturers instructions for a 5" bosch angle grinder
Since most manufacturers require a valid model number to obtain a owner's manual, I can't give you the direct link for your 5" grinder without that information.
However, here's a link to the Bosch web site and their manual section where you can enter in your model number and get a free download of the manual you can save on your computer or print out.
I suggest you set up a new folder on your PC titled "household items" and save a copy titled "Manuals" etc. so you will always have a copy for future use and reference.
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
I hope you find this Very Helpful and best regards!
Oct 09, 2009 | Bosch 5" Small Angle Grinder
How do you take a bosch coffe grinder apart?
Using a screw driver or the old butter, pry off the bottom piece.  Be careful though, getting it back together is really tricky if you don't pay attention to where all the parts go.
Feb 05, 2008 | Bosch MKM 6000 Electric Blades Grinder
Bosch Power Tools Mini Grinder Spindle 1 EA 114-1375A Logo
Top Bosch Power Tools Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Power Tools Saw Expert? Answer questions, earn points and help others
