Question about Frigidaire Refrigerators
STICKY LIGHT SWITCH
Light sometimes does not turn on when opening door
  • 84 Answers
SOURCE: Interior lights won't turn on when door opens
Do you have electric locks in the vehicle? One test to do is turn on the car's headlights and open the door. You should hear a chime when you open the driver door. One other thing is to unlock the doors with the remote if you have a remote open the driver door, get in the car but don't put the key in the ignition. The doors might relock after 15-20 seconds. This proves that the door signal open is not being processed. Just tell me what model VW and what year and if you have electric locks and I'll help you.
Posted on Oct 31, 2008
  • 141 Answers
SOURCE: Interior Light sometimes will not shut off in Ford Ranger Pick up
If I am not mistaken, the plunger is located in the door with the latch. Most of the time you can just pull the door panel off and adjust the switch. After opening and closing the door, they get knocked out of adjustment. I sincerely hope that this helped you. Take care and best wishes.
Bryon
Posted on Mar 20, 2009
  • 102 Answers
you have a bad drivers door latch, the micro switch inside is not telling the computer that the latch has been opened which would normally mean the door is open.
Posted on Mar 31, 2009
localwonder
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
ted1430
  • 339 Answers
SOURCE: Refrigerator turns off and on (intermittently) unpredictably
There's probably something sticky inside the button between the plunger and the housing or the spring inside is weak. Try to clean it out. If that doesn't work then replace it.
Posted on Oct 04, 2009
Light in refrierator won't work
If the light still didn't work and you are sure the bulb is good, then the next thing in line to check is the door switch. Off the top of my head, I'm not sure where the door switch is on this model, but the switches are usually at the bottom. Door switches are notorious for getting sticky. Lots of things get spilled in the fridge and run down to the switch. If the switch doesn't pop out when the door is opened, the light won't come on. Usually just working the switch and cleaning any sticky stuff from it fixes the problem. If not and you have a meter, you can check the switch. If it checks bad with a meter, then it has to be replaced.
Hope this helped
Jul 23, 2010 | Kenmore 57029 Side by Side Refrigerator
Having trouble with door ajar dome light staying on when door is not actually ajar?
There is a switch that connects to the door latch inside the door. They can get sticky or come loose causing your complaint. Usually it is the drivers door since that door gets used the most. The door panel has to come off to access the switch. Sometimes you can remove the dome light fuse to take care of the light and indicator until it gets repaired.
Jan 10, 2010 | 1998 Ford Explorer
How do I turn off my passenger door adjar light?
The door ajar switch is in the door latch, spay some wd-40 at door latches and open and close door's, could be switch is sticky.
Jan 04, 2010 | 2006 Ford Explorer
The door ajar light on the instrument cluster is lit, and the interior lights stay on when the car is off. The locks will lock with keyless but the lights stay on cause of the door ajar. I have pulled...
one of the switches is stuck in the door latch try spraying the door latches with lots of good penatrating oil (not wd 40 ) slam the doors sevral times till the light gos out dont forget the rear door now you can take it to the dealer and they can tell you witch door it is causing this problem but they want $$$$$ now also the switch is replaceable but iy is a lot of work dont woory about the lights killing the battery as they will turn off in 5 to 10 min
Dec 31, 2009 | 2003 Ford Explorer
Oct 04, 2009 | Refrigerators
How to get to stop light in back window of 95 lincoln cont. Bulb is burnt out. do we change from trunk side or inside of car? also have a problem with interior lights staying on for a long time after car...
First, the stop light bulb is accessible from inside the car. The cover can be removed by pressing down on the center of the unit and pull back toward the front of the car. Once off, you will have access to the bulb itself
You have a sticky door switch. Apart from replacement, best course of action is to spray the switch (all throughout the inside of the door/lock) with WD-40. Since you're unsure which switch is sticking, repeat this procedure on all doors. Once thoroughly lubricated, open and close the doors several times. This should fix your sticky switch problem.. Best of luck.
Greg
Jun 08, 2009 | 1995 Lincoln Town Car
I have a 2003 corolla le my door light is on and wouldn't go off
I could be a door switch.  1. switch dome light to door 2. close all the doors 3. open each door one by one. if the dome light comes on then you    know that switch is good. 4. closed the door and wait for the dome light to turn off then move on to the next door. 5. If you find a door that does not turn on the dome light than bingo you have a bad door switch. * the door switch may be your problem because of the constant abuse of slamming, closing , and opening the doors. * This test is not 100%. it is just a visual test. and sometimes with a simple visual test you can diagnose your problem while saving time, and $ Good luck!
Mar 29, 2009 | 2003 Toyota Corolla
Bryon
Mar 20, 2009 | 1997 Ford Ranger SuperCab
Courtesy light will not go off
Is the courtsey lamp knob turned on?
If not, it sounds like a bad door switch, courtesy light switch, or shorted wiring. Open the driver's side door and locate the door switch, it is usually near the hinges somewhere. Examine the switch and too see if any parts appear broken or snapped off. Rapidly push the switch in and out a few times and see if it has any effect on the lamp. Do the same with the passenger door switch. Also try rapidly turning the courtsy light switch knob on and off.
If you don't notice anything, you can try removing the switches and testing it with a multi meter or continuity meter. Both of these tools are available at an auto parts store if you do not own one. Let me know if you need help removing and testing the switch.
Jan 08, 2009 | 1993 Ford Mustang
Refrigerators Logo
12 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
