Question about Sanyo TRC-8080 Desktop Cassette Voice Recorder
I don't know how to get the foot pedal to work.
I replaced the brake pedal on my 2002 Kawasaki Mean Streak, and now my brake lights don't work from the foot pedal or the hand brake
check the bulb first if stayed on gets hot and blows easy. then if staying on adjust the switch
Feb 26, 2013 | kawasaki Motorcycles
Problem with terrano brakes
sounds like a faulty master cylinder. be careful driving it....
replacement/rebuilt parts are relatively inexpensive.
If you don't know how to bleed brakes, get a mechanic to replace it.
Sep 30, 2012 | Cars & Trucks
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
During transcription, when you release the foot pedal, the tape automatically rewinds a little so you can resume easily. This no longer happens with my machine. I have tried several foot pedals, but the...
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
dictationmall
Nov 01, 2011 | Panasonic RR-830 Desktop Cassette...
I am a transcriptionist who is remotely accessing a work computer
I looked a the Infinity IN-USB-1 foot pedal, thanks. I would go out and buy a second foot pedal for home then you can remote your work pc by using the foot pedal from home. Make sure you install the drivers for the foot pedal at your home pc. If this doesnt work, you can always take the pedal back to the store. I figure that If you took away your mouse from your home pc, you could not move your mouse on the work pc. It maybe the same with the pedal. Let me know if it works.
WBTech
Jan 19, 2010 | Computers & Internet
Slight air hiss or sucking sound near brake pedal and no
It maybe, I don`t know the vehicle personally but on Trucks and Buses, when this occurs, it usually points to the master cylinder piston seals which moves in and out as the foot pedal is operated. Does the hiss alter as the pedal is pushed down?? Does the hiss reduce or increase as the pedal is pushed down?? If it does, I think you`ll find that it`s this air seal between the piston and cylinder that`s failing and not the servo. Whether you car works the same way, I don`t know but I presume it must. Ian
Aug 06, 2009 | 1995 Chevrolet K1500
Foot pedal does not function on pfaff 7550
my pfaff sewing machine footpedal sticks
May 24, 2009 | PfaFF Creative 7570
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
Sanyo TRC-8080 Desktop Cassette Voice Recorder Logo
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
