Question about HP LaserJet Office Equipment & Supplies
Fuji xerox smb error 031-555 - LaserJet HP Office Equipment & Supplies
2 Suggested Answers
SOURCE:
SOURCE: xerox cannot scan to home folder.....error 027-516
home directories mustbe on the same server as ads is, meaning if you setup xerox ldap lookups on server SERVER1 with ip of 192.168.1.50 then the home dirs have to be on the same or an additional domain controller, Xerox software is stupid to this matter and does not like cross server home directories.
Posted on Aug 04, 2010
Fuji xerox DC-II 3005 have 027-516 error, how to solve?
[Cause] During the transfer using SMB of the scan to PC
feature, the SMB server could not be found.
[Remedy] Take one of the following actions, and try again:
Check the following to see if the destination SMB server
and the machine are set up properly for network
communications:
- Check the network cables are plugged in securely.
- Check the TCP/IP settings.
- Check communications of port 137 (UDP), port 138
(UDP), port 139 (TCP).
Check the following to see if the computer correctly
works as an SMB server.
- Check if the file sharing service for Microsoft
Network is activated.
- Check if [NetBIOS over TCP/IP] for TCP/IP
is activated.
- Check if the file sharing service (using
communication through port 137 (UDP), port 138
(UDP), and port 139 (TCP)) are authorized for the
Firewall settings.
For communications which exceed the subnet, check the
WINS server settings, and check if the server address
can be resolved correctly.
For Windows NT 4.0 Server/Workstation, use the
following steps to see if the NetBIOS interface device is
activated on the destination SMB server:
1. Select [Start] > [Settings] > [Control Panel].
2. Display [Services], then select [Messenger] service.
3. Select [Startup] > [Auto] > [OK], then select [Close].
4. Select [Devices] in the [Control Panel], then select
[NetBIOS Interface].
5. Select [Startup] > [Auto] or [Manual] > [OK], then select
[Close].
6. Reboot the
Oct 11, 2016 | Xerox Office Equipment & Supplies
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Xerox scanning error 027-516:server connection error in smb
This means that your machine cannot connect to the network share to which it is supposed to write the scanned documents.
There may be several causes:
- if it worked before, perhaps the server or computer with shared folder to which the Xerox unit is configured to write files is unavailable/switched off, or the shared folder is not shared anymore or has changed security permissions, preventing the Xerox from writing, or the share name has changed
- if it never worked, perhaps the Xerox needs configuring prior to use (how it should deliver the faxes, via network share or email). Refer to it's manual on how to configure scan delivery.
Jul 24, 2011 | Computers & Internet
Xerox cannot scan to home folder.....error 027-516 smb
Apr 08, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
I need the diferences between docucolor 12 and xerox 7132? please
Pretty vague question.
The Doc 12 probably has a Fiery Network controller, while the 7132 has a Fuji/Xerox controller.
The Doc 12 would have limited scanning capabilities while the 7132 can, depending on the config ordered, scan to E-mail, SMB, FTP, Scan to PC, and scan to a mailbox on the Xerox itself. If you have an embedded fax in the configuration, you can set it to catch incoming faxes and forward to e-mail, or a SMB or FTP folder on your PC or server.
The 7132 is rated at 8 pages a minute in color mode, and 30 pages a minute b&w.
The Doc 12 has been around since 2002, the 7132 is about 3 years old and has been replaced by the 7232.
Jun 23, 2009 | Xerox DocuColor 12 Color Copier
Open Questions:
HP Wireless Printer Tech Support pHoNe%%[+l26O{0O64}^]:~%%NumbER Wngjsery HP Wireless Printer TeCh SuPpOrT Number +[185526O{0O64}]WngLogin HP Wireless Printer customer service phone Number Repair service center to resolve all HP Wireless Printer products. HP Wireless Printer is an American multinational company which was founded by Michael HP Wireless Printer using its company headquarters in Round Rock, United States of America. Contact HP Wireless Printer for Setup & Installation HP Wireless Printer Setup Free & Installation HP Wireless Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for HP Wireless Printer Connect, HP Wireless Printer TECH Free Phone Number you'll be searching out HP Wireless Printer Connect setup as well. So, here we're with all cthe setup process and for your to HP Wireless Printer Connect. Get HP Wireless Printer Setup Instant Free HP Wireless Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of HP Wireless Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 19, 2019 | HP Office Equipment & Supplies
881 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
