1993 Buick Century Logo
Anonymous Posted on Jun 20, 2009
Engine hi engine diagnose lite on scantool
Engine hi engine diagnose lite on scantool say code 16 buick century 1993
engine 3.3
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
215
Points
Ay chek all the ground wires that go to the ecm
chek alterneter and battery
chek ignation module and the knock sensor
every won was good
than ay change the ecm and the problem is over
1helpful
2answers
Where is the starter Relay located on a 1993 Buick Century?
MANY POSTERS HERE LIE. THEY GUESS FOR POINTS.
SAD NO? MY ANSWERS ARE FOR USA CARS ONLY NOT THE GM BUICK EXPORT.
NO ENGINE TOLD AT ALL. OF 3., 2.2L, 3.1 OR 3.3L???????
WHY ASK FOR PARTS THAT DO NOT EXIST. ?
ASK HOW TO DIAGNOSE IT. ?
BATTERY NOT DEAD OR WEAK. IS FIRST
FUSE NOT BLOWN (ALL)
KEY-SWITCH GOOD
PRNDL SWITCH DEAD IN PARK AND OR NEUTRAL
SHIFT TO NEUTRAL AND CRANK, AS THE USERS GUIDE TOLD YOU.
93 CENTURY SCHEMATIC FROM SM BOOK, USA
AS JEFF SAID THERE IS NO RELAY. NO MATTER HOW MUCH YOU WANT ONE, 'IT IS NOT THERE"
USE A VOLTMETER TO FIND THE POINT IF FAILURE
FIRST IS HEAD LAMPS MUST WORK. SEE WHY
FUSE LINK C BLOW KILLS IT ALL DEAD.
BATTERY DEAD WEAK LAMPS GLOW DIM
THEN KEYSWITCH TESTS GOOD.
THEN PRNDL BAD (P AND N BOTH DEAD)
THE STARTER CAN BE HOT WIRED KEY OFF.
BATTERY 2 CABLES 4 LUGS NOT LOOSE OR RUSTY .
93-undefined-undefined-0_1.jpg 2 MAN TEST, USING VOLT METER CRANKING
FINDS IT FAST. AND EASY
2answers
'93 buick century battery drain
unhook hot wire to alt at night if batt is up the next morning it is the alt
Buick Century 1993, 3.3 engine. Car runs for a few seconds and dies, it will not start again until it sit for a while. Trying to diagnose fuel pump problem. I undo fuel line at engine, pump runs for a few...
The fuel pump will run on a prime cycle for approx 5 seconds whenever the key is turned on, but only after it has been off for at least 10 seconds and whenever there is oil pressure.
My buick century check engine soon light is on...and its orange..car making bumping noise and accelarates slow...to a point where the bumping noise gets louder...any answers?
Get the codes pulled. The check engine soon light means there is a issue that needs to be addressed. Once you have the codes pulled you can use them to diagnose and locate the issue.
2helpful
2answers
1993 buick century 3.3 transmission modulator help
it is located on the side of the transmission case, it has a vacuum hose going to it, make sure that hose is good and has vacuum from the engine going to the modulator, here is a picture of the modulator so u can ID it.
1helpful
Check engine light is on
the car's ecu detected a problem. you need an obd2 scantool or a code reader to extract the code so you know what causes the check engine light. or take it to a shop and have them diagnose the problem. usually its an emission related problem
I have a 2003 buick century and the service engine soon light came on as i was driving it what could be the problem pryor to that the anti lock light was on ans also the security light
service engine light refers to a computer related problem. you will need to access the computer link,retrieve the code that turned the light on, and follow a flow chart to diagnose
4helpful
Start and gif code 16 and 42
CODE 16 is DIS DISTRIBUTORLESS IGNITION SYSTEM CIRCUIT. CODE 42 ELECTRONIC SPARK TIMING EST CIRCUIT.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
